FBO VAcuum Adavance Distributor?
#1153837
01/10/12 08:28 AM
01/10/12 08:28 AM
Posts: 5,444 Indiana
YO7_A66
Indiana
Is anyone running the FBO vacuum advance distributor? The quality looks to be good.
Who is the original manufacturer of the unit?
The magnetic pickup electrical connector appears to have been replaced with the Chrysler style electrical connector, which tells me that the original manufacturer might be one of the bigger named brands. The magnetic pickup has a .026" gap which might not be a MP unit but maybe a MSD unit. Thanks
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: FBO VAcuum Adavance Distributor?
[Re: lewtot184]
#1153840
01/10/12 10:03 AM
01/10/12 10:03 AM
YO7_A66
Indiana
I would be running it with my new MSD Street Fire ignition box that might not care about the .026" gap. Since it ran on a dist machine, I would like to try it but I am a little concerned about this gap. Does the MP dist come with the electrical connector replaced like this one? I don't recall my last MP unit having the two heat shrink tubes like this one. It just looks like the connector has been spliced in. Thanks for your reply.
[Re: lewtot184]
#1153842
01/10/12 11:04 AM
01/10/12 11:04 AM
YO7_A66
Indiana
I have emailed him three times over a 2 week span with no answer. Sorry about the quality of the pictures and thanks for your reply.
There is no way that .026" gap would have worked with my FBO or my MP ECU, but I will find out what gap MSD spec's for the Street Fire box.
[Re: YO7_A66]
#1153843
01/10/12 12:37 PM
01/10/12 12:37 PM
Posts: 1,163 NORTHERN VA
THESHAKERPROJECT
NORTHERN VA
..........................Are you shure about that ? I run the same dist from FBO with the FBO ecu and it runs fine , actuall way better than the stock MP one. The FBO dist LOOKS like a MP/mallery unit but side by side there are a few differences in the castings that few will notice. I just put it in the car and set the total timing that was on the FBO spec sheet and it runs perfect. The vac advance never pulls the dist out of phase like my stock MP one. If you think the gap is off just re-gap it. ![](/ubbthreads/images/graemlins/beer.gif)
[Re: THESHAKERPROJECT]
#1153845
01/10/12 01:15 PM
01/10/12 01:15 PM
YO7_A66
Indiana
""Are you shure about that?"" I was running the first gen FBO box (ballast) and it would start with no problem with .008" gap. Then I bought the second gen box (12v, no ballast) and D had me move the gap down to .004" and that box still would not light the motor. He took that box back for rebuild. That dist is still set at .004" and the Street Fire starts excellent.
I might reset the gap to .008 then unless MSD says something else.
Thanks to both of you.
[Re: YO7_A66]
#1153846
01/10/12 01:42 PM
01/10/12 01:42 PM
YO7_A66
Indiana
""I just put it in the car and set the total timing that was on the FBO spec sheet and it runs perfect.""
I didn't get any instructions with the unit but what I do know is: 18 deg initial 12 deg at 12" vacuum timing 16 deg at 2800rpms Total should be 18+16=34 I am assuming that with the vacuum advance disconnected, I set the initial to 18 degrees at my idle rpm. Then once I hook up the vacuum advance to manifold vacuum, this should add about 12 more degrees and my idle rpms will go up as soon as I plug in the manifold vacuum. Then I was planning on just lowering the idle rpms back down and rechecking the timing at idle. Is this correct? I believe that the most important part is that I have at least 10" of vacuum in D with the brake applied. Is this correct? Thanks
[Re: lewtot184]
#1153848
01/10/12 09:54 PM
01/10/12 09:54 PM
YO7_A66
Indiana
MSD replied that the .026" gap should not be a problem, but I am going to keep it down around .008" to where I have always run it. Thanks again for the replies.
[Re: YO7_A66]
#1153851
01/11/12 10:12 AM
01/11/12 10:12 AM
Posts: 11,081 Berlin, N.J.
abodyjoe
Berlin, N.J.
sounds right..
initial timing 18* then you plug the advance in and you'll end up with 30* at idle and cruising.. so yes lower you idle.
then when you have full throttle and the vac drops out you'll be full mechanical. 18* initial + 16* mechanical will give ya the 34* total for full out runs.
did you get this set up for your combo? or did you buy it used?
mine is set up a little different. mine is 14 initial, 18 vac, and 20 mechanical.. but i have a basically stock 74 360 in my car.. it runs nice in my car..
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt. www.MoparMisfits.com
[Re: abodyjoe]
#1153852
01/11/12 10:21 AM
01/11/12 10:21 AM
YO7_A66
Indiana
"" did you get this set up for your combo? or did you buy it used?"" I called FBO to buy a new distributor and I requested at least 24 degrees initial to keep my vacuum up. FBO explained that they "usually" try 18 initial and then bring in an addition 12 with the manifold vacuum on their SB setups. I like this setup better than my current 24 initial for hot startup reasons. The new distributor will crank with 18 degrees instead of my existing 24, then as soon as the engine starts it will kick in the extra 12 for idle. I can't wait to run it this spring with 30 degrees of timing at idle. Thanks for the reply.
[Re: YO7_A66]
#1153853
02/27/12 08:43 AM
02/27/12 08:43 AM
YO7_A66
Indiana
I finally got around to installing this distributor and with it hooked up to manifold vacuum, the idle was rock steady and so was the vacuum reading. I installed it at 18 degrees per the instructions, and I got 14"hg vacuum reading at my normal N idle. Then I plugged in the vacuum line to the manifold source (per FBO's instructions) and then the vacuum jumped up to 16"hg but 200rpms higher than before. Once I readjusted the N idle rpms back down, I ended up gaining one hg of vacuum at the same idle rpms that I had previous to this swap (24 degrees of initial with my previous distributor w/o VA). So now I have 15" hg at my normal N idle rpms (previous 14") and I now show 32 degrees of timing, and I had to back down on the throttle plates around 1/4 turn. I like this manifold vacuum setup because it cranks with 18 degrees of timing, then once the engine is idling the manifold pulls the timing up to 32 degrees at my normal N idle rpms. It did show leaner on my O2 gauge but that will be an easy fix. The FBO distributor is setup with the proper can for manifold vacuum and it appears to work well. ![](/ubbthreads/images/graemlins/thumbs.gif)
[Re: 70Duster440]
#1153855
03/04/12 09:02 AM
03/04/12 09:02 AM
abodyjoe
Berlin, N.J.
Is it supposed to be actuating the canister at idle? I had him recurve a new MP distributor years ago. Came back with the recommended 18* initial and it does not pull in extra timing at idle. I have 18* initial whether the vacuum canister is connected to manifold vacuum or not. Seems like you'd have the potential for erratic idle if it were.
not sure how he set yours up but he set mine up to actuate the vac canister at idle. i have over 30* of timing at idle. it idles rock steady at 750 rpm..
[Re: YO7_A66]
#1153856
03/04/12 11:24 AM
03/04/12 11:24 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
FBO's work is excellent. I talked to Don. He asked me a gazillion questions. Custom curved the disributer based on the gazillion questions. Dropped it in my engine. PERFECT. Right out of the box. ![](/ubbthreads/images/graemlins/thumbs.gif)
