440 oil leak #1153445
01/09/12 01:17 PM
01/09/12 01:17 PM
leawood, ks
johnv Offline OP
johnv  Offline OP
leawood, ks
I had an annoying oil leak last summer, and it looks like it is coming from the dynamic seal on the front of the crankshaft, the seal that mounts in the timing cover.
The large hole in the timing cover is about .050 off center high (the crankshaft is low). It is an aftermarket timing cover and an aftermarket crank. The block has been line honed if that matters.
So - I was wondering what is the best way to fix this?
Thanks in advance
Re: 440 oil leak [Re: johnv] #1153446
01/09/12 01:22 PM
01/09/12 01:22 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
Do you have the oil-slinger on it ?
Re: 440 oil leak [Re: dOoC] #1153447
01/09/12 01:52 PM
01/09/12 01:52 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
If it is off by .050"
The only way for your cover to work is to modify the dowel holes so the seal "self centers" then tighten the bolts. However you may run into issues with bolt hole alignment and have to modify those also
If you just replace the seal using the same cover "unmodified" the problem will never go away regardless if it has a slinger or not
I'd buy a quality timing cover or a used O.E.M. install a new seal and be done with it
Re: 440 oil leak [Re: johnv] #1153448
01/09/12 01:59 PM
01/09/12 01:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Thanks in advance
This tells me the problem is with the aftermarket timing cover , what brand is it ?
As Road Hazard said you need to move the timing cover up.
Re: 440 oil leak [Re: roadhazard] #1153449
01/09/12 02:03 PM
01/09/12 02:03 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
if it was line honed wouldn't that put the crank higher? did you install the dampner before tightening the timing cover bolts?
Re: 440 oil leak [Re: dirtybee] #1153450
01/09/12 02:05 PM
01/09/12 02:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
yes it would put it higher , the cover is located by the dowels on the front of the block , so your thought of bolt tightening does not matter.
Re: 440 oil leak [Re: JohnRR] #1153451
01/09/12 02:57 PM
01/09/12 02:57 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
If someone line honed it that much they should be ashamed of them selves. Besides what the heck timing chain would fit on it after that
Re: 440 oil leak [Re: roadhazard] #1153452
01/09/12 03:25 PM
01/09/12 03:25 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
This type of problem and fix are pretty common on Slant 6 motors with stock covers. Once lined up properly and bolted down, the modified covers seem to do the job.
Re: 440 oil leak [Re: jbc426] #1153453
01/09/12 04:21 PM
01/09/12 04:21 PM
leawood, ks
johnv Offline OP
johnv  Offline OP
leawood, ks
Thanks for the responses, my thought was to try an OEM unit, and check it thoroughly before sealing it up. Do I need to drop the pan to get it sealed correctly?
Re: 440 oil leak [Re: johnv] #1153454
01/09/12 04:43 PM
01/09/12 04:43 PM
Florida STAYcation
dOoC Offline
dOoC  Offline
Florida STAYcation
You need to uNbolt the pan slightly ....NO need to remove the pan completely.
Re: 440 oil leak [Re: JohnRR] #1153455
01/09/12 05:56 PM
01/09/12 05:56 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
there is some play around the dowels which is why it is recommended to install the dampner before tightening the bolts, it centres the seal around the hub. Always worked for me but never tried another way so
Re: 440 oil leak [Re: dirtybee] #1153456
01/09/12 05:59 PM
01/09/12 05:59 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
then you have a timing cover that is screwed up , I have never had play on dowels in stock timing covers, if there is play when new the dowels and their machining operation in the block is a total waste of time and money for the manufacturer ...
