440 engine HELP
#1153143
01/08/12 10:26 PM
01/08/12 10:26 PM
Posts: 3 Tennessee
440cuda'
Tennessee
Hello, My name is Cody and I need some help figuring out some things about my MOPAR. I have been into the MOPAR family for about 12 years now, started when I was 15 with a 400BB charger. Then at 17 got my 440 cuda from a junkyard and mississippi, now 11 years later cuda is still running and finally restored. but some problems. 1st off I am sorry for the very long post this is my first time on a mopar forum, so I feel like finally I will be able to find an answer to the 440 problems. 72'440 Truck block bored.060 over , LY con rods, steel crank .10 over .10 under, speed pro hypertectic 10.1 pistons flat top, no valve notches straight up flat as a table flat top pistons. total power rings, I dont know the piston deck height, compression height any of that just stock block bored and all put together, just with over bore and 10.1 pistons, clevite bearings, the heads are stock 452's rebuilt, stock valvetrain, the cam is a comp magnum 230@.50, 280, .480int, .480exh, the cam was not degreed, just lined up the dots, on cloyes double roller timing chain.Timing is set to not detonate and runs and cranks good? I have stock size valves, 1-3/4 ceramic coated headers, eddy performer 440 intake, performer 750cfm carb, MP electronic ignition and dist. stock pulleys and balancer. no power steering no ac, just crank water pump and alternator. I wish I knew what the HP and TQ estimation was ballpark, it has 4.30 gears with locker, 26inch dragradials, TF, with 22oo stall, axle dump 2.5in exhaust dynomax ultra flo muffs. NOW the problem the engine just feels weak several of my friends have 383s that will walk the dog on my 440, and other 440s feel so much different. It does pull ok, but it just feels like a weak weak big block with the 4.30s it should just run like heck, it has a hard time breaking the drag radials over, the engine will shift from 1st to 2nd at 6000rpm and 2n to 3rd at 6500, the car just feels like it doesnt scream and pull like a 440 should, any suggestions would be greatly appreciated. LIke i said I m sorry for the thesis length post ![](/ubbthreads/images/graemlins/smilie_help.gif) here but I m out of options, I know the 440 is a great engine and should run much better, its all I wanted as a young kid, a 440 mopar, ![](/ubbthreads/images/graemlins/3_2_116.gif)
Re: 440 engine HELP
[Re: buildanother]
#1153145
01/08/12 10:41 PM
01/08/12 10:41 PM
Posts: 8,682 Buford, GA
I_bleed_MOPAR
Buford, GA
And I would check that cam (degree it). How much timing (initial and advance) are you running?
Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) )
Re: 440 engine HELP
[Re: buildanother]
#1153148
01/08/12 10:49 PM
01/08/12 10:49 PM
Posts: 1,532 crisfield, maryland 21817
82ramIndy493
Need higher stall converter for one.
I agree with this and according to what you have there it sounds like a converter in the 3000 to 3400 area would be a good start. If you haven't done it yet have someone tune the carb and distributor to meet the specs of your engine. A out of the box carb and stock distributor are not correct for a engine setup like yours. All combinations have to have evrything calibrated to work with it. I hope you get it straightened out. With the proper changes and settings your car should run strong. I built a car like yours for a friend a few years back and his engine combo was a lot like yours except for 3.91's and he runs mid 12's.
Re: 440 engine HELP
[Re: 451Mopar]
#1153151
01/08/12 11:31 PM
01/08/12 11:31 PM
RapidRobert
Welcome aboard. As said more info ![](/ubbthreads/images/graemlins/blush.gif) cranking compression/timing initial/total and when is it all in & what springs & need HP ex manifolds. Not sure if 750 is jetted lean or not but I am guessing it isn't
Re: 440 engine HELP
[Re: LaRoy Engines]
#1153156
01/09/12 03:03 AM
01/09/12 03:03 AM
Posts: 5,169 CT
GTX MATT
CT
Ditch the carb and intake
