Dodge Stealth R/T Issue #1152875
01/08/12 03:24 PM
01/08/12 03:24 PM
Pittsburgh,Pa
Dads70RTConv Offline OP
Pittsburgh,Pa
Have a Stealth r/t twin turbo ....whenever it gets cold out the inside STINKS of raw gas ....and yet theres no smell outside and no visible leaks anywhere .......anyone have any clues as to what it could possibly be?
Miss ya Dad 3-31-55 9-21-10 70 Coronet R/T Convertible
Re: Dodge Stealth R/T Issue [Re: Dads70RTConv] #1152876
01/08/12 04:13 PM
01/08/12 04:13 PM
Kirkland, Washington
Pacnorthcuda Offline
I have a 93 (not an RT). If I were you I would inspect the fuel pump plate and lines on the top of the tank. There is an access plate in the trunk--take a look.
Also inspect the fuel filter fittings (under the battery).
Re: Dodge Stealth R/T Issue [Re: Pacnorthcuda] #1152877
01/08/12 08:31 PM
01/08/12 08:31 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
Most likely the seal that seals the tank and fuel pump assembly. However the lines from the assembly are known to rust also.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Dodge Stealth R/T Issue [Re: Silver70] #1152878
01/10/12 12:50 AM
01/10/12 12:50 AM
Pittsburgh,Pa
Pittsburgh,Pa
went and moved it today and the fuel pressure regulator was leaking so thats one problem still gonna check the tank etc to make sure
Re: Dodge Stealth R/T Issue [Re: Dads70RTConv] #1152879
01/10/12 05:13 AM
01/10/12 05:13 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Usually I found that if you smell fuel in the car when its cold out and the heater is on it under the hood most of the time. The heater pulls its air in from the cowl area so it can pull the fuel fumes right in the car. Ron
Re: Dodge Stealth R/T Issue [Re: Dads70RTConv] #1152880
01/10/12 04:52 PM
01/10/12 04:52 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
They have injector o-rings to the rails and a seal on the intake that goes around the injector bottom. You can see the front ones, so look for cracks as after 20 years on a turbo engine, they see heat and my engine they were all cracked. For a few bucks per injector and a couple hours, it might not be a bad idea to replace those too and the other rail o-rings, then you'll know it's all sealed up.
