Re: All I can say is............"DAMN".....................
[Re: Thumperdart]
#1152579
01/08/12 07:54 PM
01/08/12 07:54 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
I call it like I see it and I`m humble............it will run the number after new skins, hood scoop and back to Bakersfield we go. Comparing my old t-slips to these, I`m definitely faster in worse conditions so I`ll be back at it SOON.
Dom..
Fontana is the same altitude as Firebird here.
You were about 1850' DA yesterday.. Also alot of humidity 40% for this time of year..
If you would have been @ Bakersfield you would have been only 800' DA..
Chris..
[Re: RobX4406]
#1152581
01/08/12 09:26 PM
01/08/12 09:26 PM
Posts: 152 Ontario, Ca.
Sam Robinson
Ontario, Ca.
I don't post on here much but good to see some of the Moparts members cars out there yesterday. I am part of the starting line crew out there and I run Summit Series and other bracket races out there with my car. Rob is correct, the radial street tire cars really kill the starting line.
1957 Chevy 1/2 ton [Email]13.07@101[/Email]
1967 Plymouth Belvedere Best Et(So far)10.88@124 with mufflers
1971 Plymouth Satellite [Email]12.70@108[/Email]
1993 Dodge Dakota 4x4 318
[Re: Sam Robinson]
#1152586
01/08/12 10:12 PM
01/08/12 10:12 PM
Posts: 12,271 Overpriced Housing Central
RobX4406
Sam, I didn't mean to imply you guys don't do your job, more the tire that hits the track.
[Re: Thumperdart]
#1152588
01/08/12 11:10 PM
01/08/12 11:10 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
Where you running a air cleaner? Or bare carb. exposed to the incoming air from the scoop?
[Re: moparniac]
#1152591
01/09/12 10:53 AM
01/09/12 10:53 AM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I have seen the sixpak style scoop in a taller version to solve the problem of not getting into the boundary layer air. I beleive JericoGTX has one.
