Re: your choice of out of the box heads for 360 magnum
[Re: mcmopars]
#1152251
01/07/12 06:57 PM
01/07/12 06:57 PM
Posts: 1,012 indiana
mcmopars
indiana
cam is 544/230,9.5 convertor,750 vac.,headers,m-1 dual plane intake.may go with rpm air gap.mostly street driven.just want to go faster.i feel the heads would be money well spent.
[Re: 67_Satellite]
#1152253
01/07/12 09:55 PM
01/07/12 09:55 PM
Posts: 3,427 Toronto
mshred
Toronto
^ x2 I have Brian's RHS heads and a custom cam from him on an otherwise stockish junkyard 360 and ran the times in my sig...for how much it costs to refresh stock heads or buy other out of the box heads his RHS heads perform and hard tough to beat ![](/ubbthreads/images/graemlins/thumbs.gif) He's also a class act guy...give him a call
[Re: mcmopars]
#1152254
01/07/12 10:07 PM
01/07/12 10:07 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
The OOTB Eddy Magnum heads work very well in a street car application. The attached car has gone 11.50's, no majic. OOTB Eddy heads, a .520 cam, cast stock 360 crank, and stock 360 rods,S/P hyper pistons, pump gas, drive it anywhere, its somewhere between 3100 and 3200 # ( i think), automatic.Couldnt be a simpler combination. Only change was to clearance the pushrod tunnels. RPM airgap intake. Drives well on the street, doesnt overheat, doesnt have any bad manners. Member " 71cuda" on here owns it. PM him if you want. ![](/ubbthreads/images/graemlins/thumbs.gif)
RIP Monte Smith
[Re: mcmopars]
#1152255
01/07/12 10:09 PM
01/07/12 10:09 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
I have a set of magnum r/t steel heads let go cheap. Have crane rollor rockers too.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: mcmopars]
#1152257
01/08/12 10:37 AM
01/08/12 10:37 AM
Posts: 7,506 Az
Crizila
Az
Best band for the $, Hughes "iron rams" w/ 2.02/1.60's. A mild combo 408 with those heads will get you near 450HP.
Fastest 300
[Re: Crizila]
#1152258
01/08/12 11:53 AM
01/08/12 11:53 AM
mcmopars
indiana
i think we are mad at hughes now.although they have done me ok in the past.i am seriously looking at thier iron heads and the eddys.i was looking for real world experiances.
