Need advice Cam gurus #115189
09/04/08 06:28 PM
09/04/08 06:28 PM
Townsville
3
3_wheelie Offline OP
Townsville
Having done alot of research and reading, i think ive found a suitable camshaft for my motor
said Camshaft
Its going into:
360 punched .030 over
ported X heads(came off a pullin tractor)
M1 intake
750 holley DP
3000 stall conv
4.10 rear gear
Just want to know if im making the right choice before I buy it. Thoughts?
YutKillYut Grozny lives!
Re: Need advice Cam gurus [Re: 3_wheelie] #115190
09/04/08 06:56 PM
09/04/08 06:56 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
That cam would like good compression(whats yours),and more than a 3000 stall conveter.What weight car is it going in? Call Bullet cams and get Tim Goolsby to grind you something custom is my
Re: Need advice Cam gurus [Re: goldmember] #115191
09/04/08 08:07 PM
09/04/08 08:07 PM
Townsville
3
Townsville
Compressoin is in the 10.0 range. Car is around 3,200lbs.
Re: Need advice Cam gurus [Re: 3_wheelie] #115192
09/04/08 08:45 PM
09/04/08 08:45 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Id run a little more converter for it to work properly. 4.10 gears should be ok if youre running a 26 or 27 inch tall tire
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
