Page 2 of 3 1 2 3
Re: Help Me Spend $1500 to Go Faster [Re: The Shocker] #1151925
01/07/12 02:04 PM
01/07/12 02:04 PM
Indianapolis
Roadrunner451 Offline
Indianapolis
What you have now should run 12's with ease if you can drive it out of the hole and not blow the tires off. And I have to agree with competitionwedge. Heads, cam, and some rear springs.
My roadrunner, many years ago, with a real similar combination to what you have, but with more cam (Isky Z-35 solid) went 12.20's. The very next weekend I bolted on a set of edelbrock heads right out of the box. The next weekend I went 11.70's without changing anything else.
Re: Help Me Spend $1500 to Go Faster [Re: Roadrunner451] #1151926
01/07/12 02:26 PM
01/07/12 02:26 PM
southwest pa
bodyworks racing Offline
southwest pa
edelbrock heads on my mild 440 were good for 61 hp on the dyno. cheap horsepower imho
68 ROADRUNNER 440 HORSE POWER IS HOW FAST YOU HIT THE WALL TORQUE IS HOW FAR YOU TAKE THE WALL WITH YOU
Re: Help Me Spend $1500 to Go Faster [Re: bodyworks racing] #1151927
01/07/12 03:27 PM
01/07/12 03:27 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Sounds to me like you have enough motor/trans/rear for mid-12s easily. Me, I'd move the battery to the R/R of the trunk, put subframe connectors in it, do the 'glass ft bumper, and remove weight up front: splash shields, brackets, and wiper stuff, radio & heater if it's a dedicated drag car.
Then see what it does and what needs to be addressed. Likely a Caltracs setup & some loose ft shocks. Of course heads & more cam will pick up a bunch, but first I'd want to make sure the car applies the power you have and can handle an upgrade.
Re: Help Me Spend $1500 to Go Faster [Re: 67Satty] #1151928
01/07/12 04:47 PM
01/07/12 04:47 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I would not spend any money until I knew what it runs after its well tuned and consistant.
Re: Help Me Spend $1500 to Go Faster [Re: 67Satty] #1151929
01/07/12 05:12 PM
01/07/12 05:12 PM
Super Scamp Offline
Super Scamp  Offline
Dump the $$$$ in the heads Go wih the Flow ...
Just One Man's Opinion Mopar Mafia Racing
Re: Help Me Spend $1500 to Go Faster [Re: 67Satty] #1151930
01/07/12 05:14 PM
01/07/12 05:14 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
I guess I'm different from everybody else. I agree it should do mid 12s as-is, but since you're set on spending money, my opinion is subframe connectors,springs, caltracs & the appropriate shocks. That will probably eat up your money there, unless you do all the work yourself.
My train of thought is this: you can have all the hp you want. If it isn't going to the groundd you're wasting time & money. A more rigid platform with the proper leveraging set-up (caltracs) will allow the CAR (not engine) to put out the power necessary while staying together so you don't tear-up anything...........just my ...good luck
Re: Help Me Spend $1500 to Go Faster [Re: BSB67] #1151931
01/07/12 06:03 PM
01/07/12 06:03 PM
NY,Poughkeepsie
87MO DAK Offline
87MO DAK  Offline
NY,Poughkeepsie
I agree...Go T&T and run the crap out of it ,and see what breaks
,then fix that - and figure out what's next.
Re: Help Me Spend $1500 to Go Faster [Re: 87MO DAK] #1151932
01/07/12 08:04 PM
01/07/12 08:04 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
My #3700 69 RR ran mid to low 12's in the desert with home ported 906's with 2.14 1.81 valves, a 509 cam, 1.75 headers,3.23 gears and a 3500 stall.
The only suspension mods were shocks, subframe connectors and a pinion snubber.
I had a 800 dp and a street dominator intake, timing was set at 36*.
Your car should easily be in the high 12's right now with proper tuning.
Re: Help Me Spend $1500 to Go Faster [Re: 67Satty] #1151933
01/07/12 08:11 PM
01/07/12 08:11 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Any expenditure of $1500 that doesn't replace the iron heads currently on the motor is leaving ET on the table...
Re: Help Me Spend $1500 to Go Faster [Re: Pacnorthcuda] #1151934
01/07/12 11:24 PM
01/07/12 11:24 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
Fly to Michigan, hand me the $1500 and you can drive my Dart. It will go 12's all day.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Help Me Spend $1500 to Go Faster [Re: G-Money1320] #1151935
01/07/12 11:25 PM
01/07/12 11:25 PM
tboomer Offline
tboomer  Offline
Now that there was funny!!
Re: Help Me Spend $1500 to Go Faster [Re: Pacnorthcuda] #1151936
01/08/12 12:31 AM
01/08/12 12:31 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
Iron heads have been running 10s, 11s & 12s for decades, sure he would pick up on flow but alloy heads will soften his current compression thus reducing the amount of usable cam duration unless of couse the heads get worked, but then theres your budget out the window
every one is right, it should run 12s now, he should be askin how to spend that $1500 to see 11s
Re: Help Me Spend $1500 to Go Faster [Re: SG duster] #1151937
01/08/12 12:40 AM
01/08/12 12:40 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
truely "stock" 452's with 2.08 valves only flow like 215-220cfm.
some upgrading of head flow and a solid lifter cam is where i would go with that combo.
that being said......it should run 12-something as is.
Re: Help Me Spend $1500 to Go Faster [Re: fast68plymouth] #1151938
01/08/12 12:43 AM
01/08/12 12:43 AM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Sounds like you have a great base of parts, now add a FireCore Distributor, Firecore spark plug wires, and a Firecore coil. Cheapest peace of mind you will spend.
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Help Me Spend $1500 to Go Faster [Re: 67Satty] #1151939
01/08/12 12:43 AM
01/08/12 12:43 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Better check your math again that compression even with zero deck flat tops unless your open chamber heads usually 90+cc's have been milled to around 80cc's.
I would buy a set of Stealth's have them looked over good, and upgrade the cam...
I built a similar engine for my Cuda, stock 71 440 steel crank, KB 237's which are about .010 in the hole with my deck height, a set of OOTB Steal (82cc)thE heads worked out to be about 9.8:1 or so and the car would run high 12's with stock converter, and 3.31 gears, and a 270/.470 Comp Cam, RPM intake and bg 750 Gold Claw carb.
I know without question it would have run well into the 11's with another converter (4K) and old MP solid cam I had laying around.... but the car was a daily driver and actually got 14-15 MPG the way it was!
Re: Help Me Spend $1500 to Go Faster [Re: 67Satty] #1151940
01/08/12 12:49 AM
01/08/12 12:49 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I would go for heads, best bang for the buck. I would go for edelbrocks and do them out of the box.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Help Me Spend $1500 to Go Faster [Re: 1967dartgt] #1151941
01/08/12 10:47 AM
01/08/12 10:47 AM
ill
dennismopar73 Offline
ill
I would have to figure out WHY IS IT NOT RUNNNING THAT NOW!
Re: Help Me Spend $1500 to Go Faster [Re: Bob_Coomer] #1151942
01/08/12 02:11 PM
01/08/12 02:11 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
I've done online compression ratio calculators and worked out the math with scratch paper 'til I'm blue in the face and I'm pretty confident about my compression ratio, but if you can tell me how you worked the math that it isn't 9.75:1 I'm all ears.
Seems like you should have gone faster than high 12s with aluminum heads in your combo. I had a '72 Challenger with a 426 wedge and stock 906 heads, Torker intake, 750 vac sec that did 12.80s on used-up slicks spinning all the way through first gear. Maybe that makes a good argument for me saving the $1000+ dollars that aluminum heads would cost me.
Re: Help Me Spend $1500 to Go Faster [Re: SG duster] #1151943
01/08/12 02:13 PM
01/08/12 02:13 PM
Vista, California
67Satty Offline OP
67Satty  Offline OP
Vista, California
OK, how can I get this thing in the 11s for another $1500?
Re: Help Me Spend $1500 to Go Faster [Re: SG duster] #1151944
01/08/12 02:18 PM
01/08/12 02:18 PM
Closed chamber stealth heads would "soften his current compression" verses open chamber 452's on the motor now???
Page 2 of 3 1 2 3
