Rough idle on 440 #1151413
01/06/12 06:57 AM
01/06/12 06:57 AM
Savage MN
sanman68 Offline OP
sanman68  Offline OP
Savage MN
I have a 440 that I have been trying to figure out. It has a rough idle. I believe it has a vacuum leak. The cam is a older Hughes brand that has around 228 degrees duration at .05 lift. So I think idle should be OK. The engine is rebuilt with all new components. I had the heads milled and the intake milled to match. When timing the engine the timing marks do not line up were they should. The timing marks are off by arround 30-40 degrees. The damper may have shifted but I don’t know for sure. The vacuum at idle is about 7 inches.
My questions are
Would the engine idle OK if the timing chain was off by one tooth?
What affect would that have on were the engine liked to be timed?
I plan on putting on a new intake manifold gasket set and getting a new dampener but I would like to rule out the camshaft being out sync before I start.
I drive the car and it seems to run fine once off idle.
Sanman
Re: Rough idle on 440 [Re: sanman68] #1151414
01/06/12 09:25 AM
01/06/12 09:25 AM
(1) Find exact TDC w the ten dollar tool. (2) pull pass valve cover/all plugs & hand turn front crank bolt w 1&1/4" socket/short extension/breaker bar until both of #6 cyls' valves are open and moving and are open the exact same distance & at that point (rockover) the timing marks on the dampener should be within several degrees of each other (could be a slight bit more if sloppy chain). Not a cam guy so not sure how wild those specs are. What carb? Always idled bad? #1 get the timing right & yes may very well be a vac leak. What timing are you showing? After typing this I'm thinking setting the timing right may very well take care of it. Post any news!
Re: Rough idle on 440 [Re: RapidRobert] #1151415
01/06/12 10:22 AM
01/06/12 10:22 AM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Sounds silly but make sure your spark plug wires are on correctly. I hear that a lot of people mistakenly cross the #5 and 7 wires.
Scott
1969 Super Bee, 383/4 speed
Re: Rough idle on 440 [Re: StukaJU87] #1151416
01/06/12 11:49 AM
01/06/12 11:49 AM
Savage MN
sanman68 Offline OP
sanman68  Offline OP
Savage MN
I will check the spark plugs 5 and 7. I have a thing to put in the spark plug hole to find TDC. Ir did not line up with the TDC on the damper, so I'm ordering a new one now. Once I get the new damper I could check the cam phase by taking off the valve cover. Then I will try to tackle the vacuum leak.
