Re: Front Disc Brake rotor issues 1970 Roadrunner NEED HELP
[Re: Mr. Anderson]
#1150554
01/04/12 09:25 PM
01/04/12 09:25 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
Do you have the caliper piston retracted all the way back into the bore of the caliper? I have had your problem a time or two in the past when both replacing rotors and pads at the same time, with new. But nothing that sanding down the new pads a bit didn't take care of. Sometimes manufactures tolerances aren't the greatest anymore, when your trying to fit new parts together at the same time. Where did you get the rotors? Rotors for the 70-72 B & E body cars aren't the easiest things to come across these days. Unless you got the wrong parts, or mix boxed parts, your now screwed, as you already machined the new rotors that you just installed. You won't be able to return them, if they are indeed the improper ones. The only other thing that i can think of, is the bearing race in the hub of the rotor, isn't seated all the way down, or that area in the rotor was machined wrong from the git go. Anyway, good luck in getting it figured out. Jim V.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: Mr. Anderson]
#1150559
01/05/12 03:30 AM
01/05/12 03:30 AM
Posts: 10,135 A Red State
SNK-EYZ
A Red State
Year One has the 70-71 two piece rotors, but they're pricy. http://www.yearone.com// Part # Description Price Add to Cart NG122 Hub and rotor assembly for 1970-1972 B-body models. $269.99 I thought that the only issue with using 73 and up rotors was the bearing size (which the Dr.Diff spacers fix).
[Re: FY1AAR]
#1150560
01/05/12 11:31 AM
01/05/12 11:31 AM
Posts: 75,015 U.S.S.A.
JohnRR
U.S.S.A.
I think the OP was just wondering if any else has run into this problem ..... not how he is screwed.
Doesn't really matter now if someone has the same problem , he can't return the incorrectly made parts once he modified them unless he has a real good relationship with the counter person and can prove this is an a manufacturing screwup. The rotrs are more than likely the problem , he might be able to get a refund on those , the pads I doubt .
Mr. Anderson , either get the dr. diff spacer and use the later rotors or if this is a correct resto trailer queen pont up for the Y.O. parts .
If you want to go thru the leg work you might be able to prove the Vatozone parts are incorrectly made and get a refund on the parts you machined .
