Re: Vented or Non-Vented Cap On Coolant Recovery System?
[Re: Hemi_Ram]
#114968
09/04/08 05:01 PM
09/04/08 05:01 PM
....appears to be doing its job; although the system only gets pressurized when it is real hot...
What do you mean by this? You referring to the radiator? The radiator (engine cooling system) should start to pressurize after just a couple of minutes run time, and you can feel that by feeling the top hose.
The coolant recovery tank MUST be vented
Is your rad cap designed for recovery? The "non" recovery caps generally have sort of a brass washer around the outer rim, and a rubber seal for the pressure seal in the center.
The coolant recovery (radiator) caps --all I've seen--all have a rubber seal around the outer rim as well.
Once again, the recovery tank MUST be vented.
[Re: Hemi_Ram]
#114974
09/04/08 05:36 PM
09/04/08 05:36 PM
Posts: 13,621 md
mopars4ever
md
Mike the system works great; coolant tank is vented and the cap allows the coolant to enter the tank when hot and, as advertised, it syphons the coolant back into the radiator when it is cooling down
I`m not really sure what you are asking? Mike
[Re: Hemi_Ram]
#114980
09/04/08 07:36 PM
09/04/08 07:36 PM
Posts: 26,032 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I just got one of those fancy Thermo-Caps and it has a spring loaded disc. I was skeptical if it would work on a recovery system but it does. http://www.accel-ignition.com/ProductDet...p;minselection=Goes against everything I ever learned, recovery systems should use the "dangling disc". ![](/ubbthreads/images/graemlins/shruggy.gif)
