Re: 1969 Barracuda M code
[Re: moparfan53]
#1149531
09/28/14 05:15 AM
09/28/14 05:15 AM
Posts: 17,524 Las Vegas, NV
6bblgt
Las Vegas, NV
What has puzzled me over the years is why they were shipped loose to be installed at the dealer, instead of the factory doing it. I am assuming the price list info is correct regarding that.
If they were indeed shipped loose to be installed at the dealership, I would "ASSUME" when properly installed, they interfere with the shipping tie down points.
[Re: 68KillerBee]
#1149532
09/28/14 05:36 AM
09/28/14 05:36 AM
Posts: 27,483 So Cal
autoxcuda
So Cal
Red fender liners. Never knew they had that.
The code for them is J35. I don't see that on the tag.
Was that a code that was broadcast sheet only?
Without it on the tag and no broadcast sheet, no way to prove originally had them. ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: drgordi]
#1149533
09/28/14 11:23 PM
09/28/14 11:23 PM
Posts: 8,356 fredericksburg,va
cudaman1969
fredericksburg,va
My motor is back from Koffels place. All ready for assembly. Should I put the stock cam back into it or go with the .484? I have it new in the box.
Can you say AGGRAVATION, low vacuum,bad idle, not worth th hassel, 440 is powerfull enough to fry those little tires. After the first couple of guard rail encounters you might want to de-tune it. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: 2abodymcodes]
#1149535
10/08/14 06:51 AM
10/08/14 06:51 AM
Posts: 1,187 USA
big-block-dave
USA
M-fastback on ebay, it's been in the registry but not sure yet if owner info is still correct. http://www.ebay.com/itm/Plymouth-Barracu...;_qi=RTM1562569
I'm the CARETAKER of Weinstats '69 440 'cuda registry and have 104 of the 360 cars to date. 84 fastbacks/20 coupes. Always looking for new(REAL M-code) '69 440 'cudas to add to the registry so drop me a note if any are found or known. This isn't a publicly released registry. Thanks, Dave
[Re: big-block-dave]
#1149536
10/08/14 11:18 PM
10/08/14 11:18 PM
Posts: 273 ontario, canada
plumcrazy704406
ontario, canada
lord,that ebay ad was tough. Didn't get past the second line. I've had better luck with eye teasers.
This thought may not be politically correct, but is an opinion offered. It may be correct? or it may be wrong? It is not designed to appease those needing shelter from the real world.
[Re: drgordi]
#1149539
10/10/14 10:52 AM
10/10/14 10:52 AM
Posts: 1,347 Wahoo Nebr
vette1986
Wahoo Nebr
I am a little shocked that this car is not moving at all on the price?? What is wrong with this one holding it back as it is a no reserve auction and he can only stop the auction if it is done before it gets down to the last 12 hours. I wonder if it gets pulled today before then? I would have said the LOW end on a driver M code cuda would be in the 30's and on up based on quality. Am I missing something on this one ??
1969.5 A12 Bee EV2 1971 Charger RT 1973 Duster tubbed 500 low deck 10.90 monster 3 440 polara vert projects
[Re: vette1986]
#1149540
10/11/14 10:05 AM
10/11/14 10:05 AM
Posts: 1,187 USA
big-block-dave
USA
Yeah I thought it was odd to have no reserve! Looks like he ended the auction. I asked him to email me on my m-cuda only address to discuss the car. He hasn't contacted me, so I don't know if it's still owned by the same person in the registry?
#1149544
10/20/14 08:10 PM
10/20/14 08:10 PM
cudaman1969
fredericksburg,va
Just wondering if there is a paint code for the black on the lower front and rear body or should I just get the stripes and match it to that? And who makes the most accurate stripes for the cuda? Paint is soon to fly and I need to get the black done first.
No paint code as far as i know.
Is it flat black or the black hood textured paint?
