Re: 1969 Barracuda M code
[Re: Rhinodart]
#3195787
12/06/23 10:21 PM
12/06/23 10:21 PM
Posts: 43,575 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Quarter damaged why it was parked in the late 70's
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#3195852
12/07/23 10:53 AM
12/07/23 10:53 AM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
Quarter damaged why it was parked in the late 70's Is that the original engine ?
[Re: JohnRR]
#3196361
12/09/23 09:39 PM
12/09/23 09:39 PM
Rhinodart
Rhinotruck
Rhinotruck
Quarter damaged why it was parked in the late 70's Is that the original engine ? Yes. The valve covers on it are later just to keep the rodents out. The distributor, carb, air cleaner, and radiator were all taken when the car was in a farmers field in the late 70's...
A-Body's RULE!
[Re: Rhinodart]
#3198782
12/19/23 11:26 PM
12/19/23 11:26 PM
Posts: 21,520 N.E. OHIO, USA
A12
N.E. OHIO, USA
What oil pan (again sorry) is on the M-Code Cuda and Darts 440? Can I use a 402
[Re: A12]
#3199027
12/21/23 12:34 AM
12/21/23 12:34 AM
Posts: 3,394 cheshire, ct
davesmopars
cheshire, ct
What oil pan (again sorry) is on the M-Code Cuda and Darts 440? Can I use a 402 893 Is the correct pan. The 402 pan will work but the center link will hit it causing a small dent
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: A12]
#3199123
12/21/23 02:02 PM
12/21/23 02:02 PM
Rhinodart
Rhinotruck
Rhinotruck
What oil pan (again sorry) is on the M-Code Cuda and Darts 440? Can I use a 402 You can buy a new 893 reproduction from www.vansauto.com as they used one of mine when they did them...
A-Body's RULE!
