Adjusting Rancho Shocks
#1148524
01/02/12 11:38 AM
01/02/12 11:38 AM
Posts: 1,009 Richmond Twp. Mi.
Mr340
Richmond Twp. Mi.
While installing my Offset spring hangers I decided to upgrade shocks from the Mopar ones to Adjustable Ranchos Looking at the new shocks last nite the dial only turns half way around, that seems like only 5 settings. How do you get to the other 4 settings? is there a detent? Push-in, pull-out on the knob? I've tried both and nothing seems to help. What am I missing, or did i get a defective set?? I'll call the tech line tomorrow but thought I'd ask here first. thanks.
Re: Adjusting Rancho Shocks
[Re: MagnumDartSport]
#1148529
01/02/12 06:04 PM
01/02/12 06:04 PM
Posts: 4,852 KENTUCKY
69CHARGERMD
KENTUCKY
Mine go to 11, sorry, couldn't help the spinal tap analogy,,,,
My ranchos' have a 1,3,5,7,9, with spacing in between,,,
[Re: Labratt]
#1148531
01/03/12 01:45 PM
01/03/12 01:45 PM
Mr340
Richmond Twp. Mi.
Called their tech line this am and the tech said turn the knob CC and if #5 is at 12 o'clock the knob is installed 180 out remove and reposition it. If 1/9 is at the top the shock is defective, return them. Well mine stopped @ 1/9, decided to take it apart and look at it. Cleaned everything up and reinstalled the knob and I now get all 9 settings I guess the valve was a bit sticky, they seem ok now, I'll just have to see how the perform. Thanks Guys.
