Help on 440 build
#1148277
01/01/12 08:30 PM
01/01/12 08:30 PM
Posts: 1,022 Green Lane, PA
sawdust
Green Lane, PA
Planning out the build for a stock stroke 440 and need some input Car is primarily a have fun all steel NSS 67 Belvedere sedan, 727, no converter selection yet, 8 ¾ w/ 4.30 gears and spool. Racing is the primary thing, not a cruiser. Has 6 pt bar and sub frame connectors currently going in, 2x3 .125 wall welded to/through the floors and to the subs. Engine parts we have Edelbrock 84cc RPM heads will do mild porting, 1.5 roller rocker arms (440 Source) Victor 440 intake, (may go with RPM dual plane though), 1.75” hooker headers, stock 440 block, will bore to .030 for build, and a stock stroke forged crank. Looking for a simple mid to low 11 second car for now. Do not want to sink a ton of money in 440 for now, that will happen in a few years when the hemi goes in it. Questions: 1. Pistons, prefer to get around 11:1 compression something around $500? 2. Rods, prefer K1 as they hold tighter side clearances but what about SCAT or Eagle? 3. .990 pin size? 4. Rings? 5. Main studs I imagine I should use, but a girdle too? 6. Cam selection; non roller thinking about .550 lift 290° duration or maybe a bit more. 7. Carb? 8. Converter? 9. Tires? Prefer streetable, no tubs.
TIA
Re: Help on 440 build
[Re: sawdust]
#1148278
01/01/12 08:51 PM
01/01/12 08:51 PM
Posts: 1,030 ohio
67mprfan
ohio
look at srp piston or icon as they are decent choices for the $$$ also eagle rods should do the job you are looking to get done,also lighten the car as much as possible
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
[Re: sawdust]
#1148280
01/01/12 08:55 PM
01/01/12 08:55 PM
Posts: 43,185 Bend,OR USA
Cab_Burge
TIA
#1 Look at KB forged ICON sereis #2 your call #3 Good choice, as lightweight as possible #4 file to fit moly set with satndard tension oil rings.#5 Good choice on main studs, not mandatory I don't like or use a girdle on B,RB or 426 Hemi blocks #6 get the biggest grind you can, .600+ lift with close to 270 degrees or a liitle more at .050 lifter opening, have it ground on a 104 to 108 lobe seperation angle Isky has a grind that is not in thier catalogs anymore that I use to use a lot, it is the 616/590 grind with 104 LSA, it works really well for a solid lifter flat tappet #7 850+ CFM, every time I used a bigger CFM carb. on stock stroke 440 drag motor it went faster, no matter what equiptment or car #8 Buy a custom built EXCELLENT QUALITY NAME BRAND 8 inch race converter, no cheap off the wall brand ones #9 Buy the biggest M/T ET Street bias ply tire you can fit on your car Probally not going to be real big due to the wheel wells on those cars I hope this helps BTW, are you going to move the rear leaf springs in at all? If so wait until all that work is done to buy rims and tires Buy the widest rear rims you can run safely on your car
[Re: sawdust]
#1148281
01/01/12 09:50 PM
01/01/12 09:50 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
not sure on the cost of mine (bought it done) but this set-up is .030 over 440 w/ ross pistons (approx 11.2:1), H-beam rods (not sure who's), stock steel crank, main studs but no griddle, ported Stage VI heads, H/S 1.5 roller rockers, 580/588 comp cams solid roller, 1 3/4" headers (2" coming soon), Stock 6-pack, Turbo Action 3800 stall, TA RMVB, 3.91's 275/60 drag radials, stock XHD springs. Can ran best of 11.39 w/ some more in it. Drive it to the track and home. I'd think you could build a mid-low 11 car w/o braking the bank...especailly if you can find some good used parts.
[Re: Mr.Yuck]
#1148282
01/01/12 10:38 PM
01/01/12 10:38 PM
sawdust
Green Lane, PA
thanks for the input from all. I am leaning towards an Icon piston but not sure of it will work with the Edelbrock 84 cc head. Icon pistonAlso guess I will shop around for a 900 CFM carb, though I like the Edelbrock carbs they just do not have the CFM. Rods wise, like the K1 rods, though the scats, ohio, and eagle rods are cheaper. I would like to keep the piston choice on the lighter side. Here is picture of the project, pretty decent starting point purchased last June from a member on Moparts.
[Re: sawdust]
#1148284
01/01/12 11:04 PM
01/01/12 11:04 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Are you planning on decking the block or maybe shaving the heads?
I have off the self Wiseco Pro Tru pistons in mine and with where my deck and heads are it's right at 12:1 so 11:1 is doable.
My old motor was nothing if not a joke build. 8.6:1 CR, LY rods, cast crank, 555 Comp solid cam, Proform 1.5 rockers (with MP adjusters) OOTB Eddy heads, a Weiand Team G and a Barry grant 750 silver claw W/ 1 7/8 hookers.
Ran a best ET of 10.96 but was usually in the 11.0's.
The kicker is the weight. Car only weighed 2820 #'s with out me in it.
How heavy is the car?
[Re: jamesc]
#1148286
01/01/12 11:57 PM
01/01/12 11:57 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Wow that car looks great. My old 440 ran a best of 11.49 in my 3700 lb 63. It was a stock 440 shortblock but with .030 over KB quench pistons. 906 heads I ported and cut for 10.0 comp as it was a pump gas eng. MP .557 solid cam. Holley Street Dominator intake and 850 DP. 1-3/4 headers and 3" pipes. Isky ductile iron rockers. Just a basic 440 but it ran slid 11.70's and 60's. Ran 50's in good air with the 11.49 best. Good luck with that nice car. Ron
[Re: jamesc]
#1148287
01/01/12 11:59 PM
01/01/12 11:59 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Wow, that should be a lot of fun! My one concern with that car could be tire size in the rear. However if you move the springs inward you can get a 10.5 tire on it.
Piston wise I would look at KB, good price should be nice and have decent valve reliefs built into it for a decent cam.
I guess my question is why not a solid roller? A lot of guys on here run them and seem to have great street manner as well.
Converter: I would suggest PTC (I have had good history with them) I would look at 3800 to 4000 stall
Carb: I would suggest Holley 750 DP with time on the dyno to get it right.
Tires: M/T street radials are awesome on the street and don't burn up just looking at them like a set of BFG's will on a nice day.
Just my two cents good luck sounds like a fun build.
Mike
1969 Dodge Dart Swinger
[Re: jamesc]
#1148288
01/02/12 12:03 AM
01/02/12 12:03 AM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
I'm with Bill on the Wiseco Pro-Tru pistons I have them in my engine with K-1 rods with the 990 pins.My engine is right at 11.1 with flattops and and basic Indy EZ heads. Nick Wilson over at www.compu-flow.com usually stocks the pistons and rods you need and can also cut the heads and help you with a cam to optimize your choices Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#1148289
01/02/12 02:10 AM
01/02/12 02:10 AM
Posts: 2,141 junction city oregon
viperblue72
If it were me: Icon piston zero deck Eagle hbeams A cam similar to mp557 Main studs or good bolts Good single plane victor,m1, or similar And just buy some nodular iron rockers in 4sale section. Holley 850-950
[Re: viperblue72]
#1148290
01/02/12 03:35 AM
01/02/12 03:35 AM
Posts: 319 jonestown,pa
dmking
jonestown,pa
i have a M1 intake 1050 dominator had stock crank stock rod dimond pistons old indy torquer 270cc@335cfm262/265@.630 lift 110ls solid in at 104 lupo comp 9" converter @5000rpms 4:10 gears slicks caltracs 10.70s @ 3200lb cam at 108 ran 10.30s less cam and less comp smaller carb should live and slow it down to mid 11s your choice but if good pistons cost 200 more and good rods cost 200 more than what you want spend it.lite is better the better the heads work also the less other stuff needs to be high strung. i am not sure how long the stock rods would of went but it did go a season that way till i blew a ring land out in the fall of that season. i now have JE pistons and k1 rods same everything else. (except block )
[Re: jamesc]
#1148291
01/02/12 10:40 AM
01/02/12 10:40 AM
Posts: 10,000 Frostbitefalls MN (Rocky&Bullw...
gregsdart
is this a race car or strip / street?
assuming its race use the victor manifold.
i don't know about those rockers, find out what kind of success people have been having with them.
pistons probably cost you a little more than $500 and i wouldn't use the replacement ones i'd use a race piston. Ross can usually be had for a reasonable price but i doubt you're gonna find a shelf piston that will hit your 11:1 mark. FT will probably fall far below that and dome above. it all depends on chamber volume, deck height, piston selection and head gasket thickness.
i have no experience with K1 but get the impression they're better than the other imports.
use the .990 wrist pin size.
i would use a standard speed pro moly file fit. make sure the bores are properly finished.
studs definitely, aluminum caps would be better. personally i wouldn't get involved in a girdle i'd use aluminum caps before a girdle. at the power level this engine should make you should be OK with stock caps but YMMV
cam selection...well can open worms everywhere. i usually buy shelf cams for stuff like this. i like the cam in my sig car. comp .585/.585-275°/275° @ .050"
carb- HP950
converter- quality 8"
tires- race cars (if that's what it is) use slicks
now someone else is going to tell you something completely different
Good advice, no arguments here, but will add some. Bigger headers (1 7/8 to 2" x 36+), size of cam and stall may allow a bit bigger carb if stall is high enough. Set the deck to .000 and cut the heads for the best compression you can get with a flat top. Size the valve pockets for as big a roller and as big a valves (2.25 intake, 1.81 exhaust?) as you ever figure you may run. Makes the short block compatible with more serious heads, like SRs or 440-1 should you ever decide to change the combo. See if there is a shelf piston and rod combo that would allow you to use the same rods in the Hemi build down the road. You will benefit from a longer rod in either combo, (weight) and just off the top of my head a 7.10 long rod would need a 1.725 compression height piston to get .000 deck at 10.7 deck height.
[Re: gregsdart]
#1148292
01/02/12 08:44 PM
01/02/12 08:44 PM
sawdust
Green Lane, PA
carb- HP950
The car is primarily strip but it would be nice to thrash on the street once and awhile.
Primary focus is the bottom end as I can always swap heads and induction but want a good short block to get a few years of fun. Will stick with the Victor 440 as recommended. The 440 Source roller rockers are one of those impulse purchases China okay quality I have a new set of crane iron adjustable rocker arms, maybe should just use them? Eagle rods sound okay. Pistons? Will these work with the Eddy heads? Brand ICON Performance Pistons Manufacturer's Part Number IC836-030 Part Type Pistons Product Line ICON Premium Forged Pistons Summit Racing Part Number UEM-IC836-030 Bore (in) 4.350 in. Bore (mm) 110.490mm Piston Style Step head, with two valve reliefs Piston Material Forged aluminum Compression Distance (in) 2.067 in. Piston Head Volume (cc) +12.00cc Wrist Pin Style Press-fit or floating Pin Diameter (in) 0.990 in. Piston Ring Thickness 1/16 in. x 1/16 in. x 3/16 in. Quantity Sold as a set of 8. Notes Step dish design. Piston weight 709g, pin weight 141g.
[Re: sawdust]
#1148293
01/02/12 10:16 PM
01/02/12 10:16 PM
gregsdart
Ross makes a flat top with a compression height of 1.728that will fit the 7.100 rod for your 440 block with a 3.75 stroke. 595 grams,210 lighter than the piston you are thinking of using. another advantage- when you build the hemi, pull the rods for that motor, and you could use a 4.375 stroke crank and 6.8 rods with the same 1.728 piston in the 440 block. Stock 440 cranks don't live forever, so it is worth considering. You would have a nice torque monster back up motor!
[Re: jamesc]
#1148294
01/02/12 11:55 PM
01/02/12 11:55 PM
sawdust
Green Lane, PA
i think i remember that car (i was kinda eyeballing it), wasn't it originally being sold complete with an engine? really nice looking car.
Car was a roller when it was listed here and CL, owner wiped out the cam on break in so he yanked the engine and trans. Forgot to mention in first post, I already have the hemi done and running in my hemicuda, just waiting to build up the original engine when either the original or a date coded block appears and swap it out. The hemi already done is in my resto post; https://board.moparts.org/ubbthreads/show...e=6#Post5789998
