Coolant leak on passenger floorboard?
#1148202
01/01/12 06:28 PM
01/01/12 06:28 PM
Posts: 164 Arizona
DartSportDude
Arizona
After driving my '73 Dart Sport 340 this morning, I noticed a pretty substantial coolant leak on the passenger side floorboard. What do you think -- does this sound like a heater core issue -- or something else? If it's related to the heater core, how big of a repair job is this? Hopefully I won't need to take the dash apart to get at it.
Also, this is a factory A/C car.
Any advice would be greatly appreciated. Thanks!
Re: Coolant leak on passenger floorboard?
[Re: DartSportDude]
#1148205
01/01/12 07:09 PM
01/01/12 07:09 PM
Posts: 8,680 Buford, GA
I_bleed_MOPAR
Buford, GA
Not too sure about your weather but you could by-pass the heater core, at least until you fix it (if you want to keep driving it). Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#1148206
01/01/12 07:31 PM
01/01/12 07:31 PM
Posts: 164 Arizona
DartSportDude
Arizona
Tim
I thought about the bypass option, but isn't that done on the engine bay side? I don't want something that looks half-assed on my firewall.
Crap, from what I've been reading, this heater core replacement sounds like a major pain on an A/C car.
[Re: DartSportDude]
#1148207
01/01/12 09:59 PM
01/01/12 09:59 PM
RapidRobert
Yes bypass it on the eng side & pull the heater/ac box to get at the heater core.
[Re: DartSportDude]
#1148208
01/01/12 10:13 PM
01/01/12 10:13 PM
I_bleed_MOPAR
Buford, GA
You can probably get some rubber caps at the parts store to plug off the hose inlet and outlet on the engine (don't forget the hose clamps ) or simply make a 180* bend in a piece of heater hose (not too pretty but not real noticeable). And while you're at it, you could push a couple of the caps on to the heater core pipes just to clean up the looks (better than the bare pipes sticking out of the firewall). And yes, removing an a/c-heater box is not for the timid of heart. Take your time and document everything, most instructions or manuals aren't that clear on what goes where.
Tim
