Hemi shaker base plate feet? #114760
09/03/08 07:12 PM
09/03/08 07:12 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Does anyone have a picture of the bottom of a Hemi shaker base plate showing the position of the tabs that are spot welded on for the feet?
Re: Hemi shaker base plate feet? [Re: sbcjd] #114761
09/04/08 10:37 AM
09/04/08 10:37 AM
indiana
mopar mike Offline
mopar mike  Offline
indiana
Re: Hemi shaker base plate feet? [Re: mopar mike] #114762
09/04/08 01:21 PM
09/04/08 01:21 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Thanks for the bump. I am not asking someone to disassemble their shaker hood- that is a lot of work- maybe someone has a factory drawing or has a picture of their restoration. Are there any indentations or markings on the base plate to show where the tabs are spot welded? Thank you for any assistance.
Re: Hemi shaker base plate feet? [Re: sbcjd] #114763
09/04/08 01:23 PM
09/04/08 01:23 PM
New Mexico
UCUDANT Offline
Troll Hunter
UCUDANT  Offline
Troll Hunter
New Mexico
PM Scott Smith, bet he'll have a pic.
Re: Hemi shaker base plate feet? [Re: UCUDANT] #114764
09/04/08 02:51 PM
09/04/08 02:51 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I would check with Scott, but IIRC if you don't have the legs it may because you have a later base. The later bases have a different size stud. Just FYI
Re: Hemi shaker base plate feet? [Re: Morty426] #114765
09/04/08 03:10 PM
09/04/08 03:10 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
This was copied from a factory print.
May seem a bit crude but it shows the location you are looking for on a Hemi base, same location on opposite side.
440- 6 pak shaker base has the brackets in the same location.
Feet brackets were sceduled to be discontinued mid 71 on 440-6 pak bases...later on Hemi bases near the end of production run.
Stud thread size is the same on all bases except the head diameter is smaller on studs used later in production.
Re: Hemi shaker base plate feet? [Re: mccannix] #114766
09/04/08 03:19 PM
09/04/08 03:19 PM
california
sbcjd Offline OP
sbcjd  Offline OP
california
Terry,
thanks for the drawing. I will go mark my base plate now. Is the other side bracket in the same location?
Re: Hemi shaker base plate feet? [Re: sbcjd] #114767
09/04/08 03:20 PM
09/04/08 03:20 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Jack
Yes same location on the opposite side..
