Re: Brake Fluid
[Re: BLACKHEMIRR]
#1147022
12/30/11 07:37 PM
12/30/11 07:37 PM
Posts: 1,300 Washington
19cuda73
Washington
Everything I've heard Dot 5 is the way to go. Thats what Im getting to put in the Cuda over the weekend. It has all new parts.
1966 Charger 383 4 speed (Black with Red interior) 1973 Cuda 340 4 speed (Lemontwist) 1972 Corvette
Re: Brake Fluid
[Re: meepmeep70]
#1147024
12/30/11 10:25 PM
12/30/11 10:25 PM
Posts: 905 SD
zrxkawboy
SD
First, all brake fluid is synthetic. DOT 5 is silicone-based, and the others are glycol-based. I have switched my vehicles to DOT 5 by sucking as much out of the MC as I can, filling with DOT 5, and then bleeding until I see purple at each wheel. No problems whatsoever.
If anyone doubts compatibility, think of the assy grease that comes with wheel cyl kits, etc. It is silicone grease, and seems to do just fine in a glycol-filled system.
It's Swifty! Swifty, you toad sucker!
Re: Brake Fluid
[Re: zrxkawboy]
#1147025
12/30/11 11:45 PM
12/30/11 11:45 PM
Posts: 697 Central IL
70Sbird
Central IL
I've done this many times, get all of the old stuff out of the M/C as you can and bleed until you see purple! NEVER had any issues in over 20 years and numerous cars!
