Drive line vibration #114685
09/03/08 03:50 PM
09/03/08 03:50 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I've been having a on going problem with my coronet. If I run it up to 5K and lift my foot I get a heck of a vibration right next to me at about the end of the tranny my slip yoke is sticking off of the tailshaft about 2.5 inches. Put another driveshaft in that measured the sme as my old one and it still does it
Re: Drive line vibration [Re: flatiron] #114686
09/03/08 04:00 PM
09/03/08 04:00 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
2 1/2 inches seems pretty far. Are you sure you have the right shaft for your combination?
More info on your combination would help too
Re: Drive line vibration [Re: flatiron] #114687
09/03/08 04:12 PM
09/03/08 04:12 PM
Appalachia
RedRam Offline
RedRam  Offline
Appalachia
IMO, If it vibrates when you lift/decelerate, it is pinion angle. The pinion is too far down. Do the front segments of your leaf springs have the straps around them or are they clamped? Might want to make sure they are strapped/clamped. Then work on pinion angle.
Re: Drive line vibration [Re: RedRam] #114688
09/03/08 04:31 PM
09/03/08 04:31 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
I'm not sure if I have the right shaft. The previous owner was the type that had no right owning a old car and Ijust keep finding one thing after the other. As for pinion angle I do have s/s springs on and they are clamped but I have no shims in place.
Re: Drive line vibration [Re: RedRam] #114689
09/03/08 05:38 PM
09/03/08 05:38 PM
hmmmm, I have a vibration too. more of a HUMMMM HUMMMM HUMMMM while I cruise that kinda goes away when I accelerate. Same thing only different (pinion too far up maybe?)
Re: Drive line vibration #114690
09/03/08 05:43 PM
09/03/08 05:43 PM
Grand Forks, ND
Hemi_Ram Offline
Hemi_Ram  Offline
Grand Forks, ND
Had the same problem a few years back with a 71 Demon; wrong length driveshaft as the yoke was sticking out too far. Measured and made up a new shaft with the correct dimensions and the vibration diasappeared.
Re: Drive line vibration [Re: Hemi_Ram] #114691
09/03/08 05:56 PM
09/03/08 05:56 PM
PA USA
flatiron Offline OP
flatiron  Offline OP
PA USA
Yeah I think that's the route I'm gonna go. It just seems like the slip yoke is sticking out way to far.
Re: Drive line vibration [Re: flatiron] #114692
09/03/08 07:11 PM
09/03/08 07:11 PM
Appalachia
RedRam Offline
RedRam  Offline
Appalachia
quick way to check is put the rear axle up on jackstands, unbolt the Dshaft from the yoke, shove it all the way in the trans. If Ujoint is more than an inch away from seating in the pinion yoke, it is too short.
Re: Drive line vibration [Re: Hemi_Ram] #114693
09/03/08 08:34 PM
09/03/08 08:34 PM
ERIE PA home of the RENCH MOB
mike_vango Offline
mike_vango  Offline
i had a vibration since i finished my car. my driveshaft is being lenghtened right now and will be done on friday. i've checked everything and this is my final attempt. hope this does it.
Re: Drive line vibration [Re: mike_vango] #114694
09/08/08 07:40 AM
09/08/08 07:40 AM
mine doesnt stick out more than an 1 1/2 from the start of the yoke to the tranny seal....
