Re: Yes ,Lickity Split is making progress
[Re: 1967dartgt]
#1146403
12/30/11 02:09 AM
12/30/11 02:09 AM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
Looks great. Cant wait to see the finished product.
[Re: dvw]
#1146407
12/30/11 06:28 PM
12/30/11 06:28 PM
Posts: 10,044 MN
JERICOGTX
MN
Your attention to detail is amazing. Keep up the good work. Jeff
69 GTX
68 Road Runner
[Re: BigFish69]
#1146411
12/31/11 07:04 PM
12/31/11 07:04 PM
Posts: 9,871 MI, usa
dvw
MI, usa
Doug could you post a closer pic of the way you mounted the tach to the dash. thanks Tom
I turned a piece of round aluminum 1.375"x.500". Drilled and tapped it for 3/8-24. Welded the original spacer that came with the tach mount to the top. The 2nd part is 2.50x1.375x.125 I bent it at about a 30 degrees. The flat support needs some gussets welded as it is to flexible. Doug
