408 Stroker blueprint engine - Oil Issue
#1146307
12/29/11 10:35 AM
12/29/11 10:35 AM
Posts: 8,430 St Charles MO
70Coronet500Vert
St Charles MO
So my friend and I are installign the blueprint series 408 in his charger. He has a dyno sheet with it 350HP and 460 ft lbs of torque, should be great motor.
Anyway, these blocks use the 93-99 360 magnum blocks as a base. On this block where the oil filter goes, they ship it with out the adapter plate for a filter. It is about a machined area 4inches in diameter.
So he went to chrysler and bought the adapter plate. put it on, but it does not fit correctly. There is like a 4" machined circle where a gasket goes and that is machined in th block. The there is a raised area in the cetner, where the adpater screws in with the nipple that the oil filter will use. This center section is raised higher that the machined area in the circle, so this adapter plate will never seal
Any ideas n this problem? do they make two adapter plates?
No matter how responsible he may seem, never give your gun to a monkey! 1970 Coronet Vert 1972 Charger 1974 Satellite Sebring Plus Sundance 2001 Ram 4x4 2002 Intrepid 2006 300C
Re: 408 Stroker blueprint engine - Oil Issue
[Re: 70Coronet500Vert]
#1146308
12/29/11 11:12 AM
12/29/11 11:12 AM
Posts: 2,826 NY usa
540challenger
NY usa
You have some incorrect information. Blueprint engines uses LA blocks with magnum heads. LA block have ears only to mount in the car. Magnums have The ears and pads.
I am not sure in magnum use a different oil filter adapter then LA ![](/ubbthreads/images/graemlins/shruggy.gif)
[Re: 6T6Cuda]
#1146311
12/29/11 03:25 PM
12/29/11 03:25 PM
Posts: 2,826 NY usa
540challenger
NY usa
Good luck with the motor... I had nothing but problems, trying to keep my blood pressure low, and not rehash everything, but in the end it had the wrong rings in it.
x2 the rings went in my blue printed engine and they didn't cover it under warranty then the was the stock broken valve springs, worn guides etc.......
It would be best to bring that to machine shop and get check out before you run it. ![](/ubbthreads/images/graemlins/Twocents.gif)
Mine cost an additional $1400.00 to get things right.
[Re: 540challenger]
#1146312
12/29/11 05:05 PM
12/29/11 05:05 PM
Posts: 1,212 Canton, Ohio
Crazy68Dart
Canton, Ohio
Wow had considered one for my brand X car... hmm maybe to good to be true.
383, Hemi 4-Speed, AlterKtion, D60
[Re: 540challenger]
#1146313
12/29/11 10:49 PM
12/29/11 10:49 PM
70Coronet500Vert
St Charles MO
OK, Blueprint told us that the block is a 93-99 truck engine. I assumed that all motors those years were magnums.
[Re: MarkZ]
#1146315
12/30/11 02:17 AM
12/30/11 02:17 AM
Posts: 9,826 las vegas
70AARcuda
las vegas
look at the casting number on the driver side of the block...
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
