Re: Another 727 question front drum this time
[Re: Otherlane]
#1145810
12/28/11 02:35 PM
12/28/11 02:35 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I have put them in a lathe and resurfaced them and run them with no problems,but if it is a stock drum good ones can be picked up so cheap it is not really worth the time.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: Otherlane]
#1145812
12/28/11 03:45 PM
12/28/11 03:45 PM
Posts: 20,678 in a cattle trailer down by th...
Guitar Jones
To use or not to use? i was told to true it and use it.Is it paper weight now?
Get an aftermarket steel or aluminum drum, safer anyway.
[Re: dOc …]
#1145816
12/28/11 07:26 PM
12/28/11 07:26 PM
dusturbd340W5
Kissimmee Fl.
A billet drum is very nice and I had 1 in my unit BUT if you know how to treat a 727 and know what to do when and what not to do a stock drum will work fine.
[Re: Otherlane]
#1145819
12/28/11 08:43 PM
12/28/11 08:43 PM
dusturbd340W5
Kissimmee Fl.
Well if its an aluminum drum the first thing is that is the wrong band to use. Should use a band with no groves with an aluminum drum. I would try and have it machined and see how much you have to take off to clean it up.
[Re: Otherlane]
#1145820
12/28/11 08:44 PM
12/28/11 08:44 PM
Posts: 16,932 NC
440Jim
NC
This an aluminum front drum
I can't be sure how deep the grooves are, but resurfacing it sounds like a good solution. Also, do yourself a favor and don't run the riveted band with the grooves in the lining. For an aluminum drum, I like the lining with no grooves (wears more evenly on the drum) and a solid backing (not the flex band). ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: Otherlane]
#1145821
12/28/11 08:50 PM
12/28/11 08:50 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Just think of all those ridges and grooves as more surface area ![](/ubbthreads/images/graemlins/grin.gif) ![](/ubbthreads/images/graemlins/wave.gif)
