Electronic Lean Burn Distributor with Crank Trigger? #1145637
12/28/11 02:13 AM
12/28/11 02:13 AM
Melbourne , Australia
LA360 Offline OP
LA360  Offline OP
Has anyone used a Electronic Lean Burn Distributor from the later 70's/early 80's with a MSD Crank Trigger on a small block? Is it as simple as changing the plug to match the MSD 6AL or 7AL?
Thanks in Advance
Alan Jones
Re: Electronic Lean Burn Distributor with Crank Trigger? [Re: LA360] #1145638
12/28/11 09:25 AM
12/28/11 09:25 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
when you use a crank trigeer, that is where the pick up is, This means the dist will not have to plug into anything as the pickup in it is not being used at all (your msd violet and purple wires go to the trank trigger). When you use a crank trigger, the distributor is only for the coil's spark to be distributed to the spark plug wires, thats it....Lean burn dist would be perfect for that
....BAD A$$ STREET CAR.....
Re: Electronic Lean Burn Distributor with Crank Trigger? [Re: LA360] #1145639
12/28/11 10:45 AM
12/28/11 10:45 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks in Advance
Like was said... the crank trigger is picking up
when to fire.... the dist is just the distribution
point for the spark
