Anyone running a Reid powerglide #1145527
12/27/11 11:50 PM
12/27/11 11:50 PM
Southern IL.
jafr Offline OP
jafr  Offline OP
Southern IL.
I just built a Reid powerglide with a Reid bell for a big block Mopar. I can't find anyone that can tell me what flexplate I need. I even talked to the engineer at Reid, what they tell you is we don't make a flexplate call one of the companies that sell our products. TCI's flexplate won't work it is the same one that they sell with their adapter plate. When you use their plate they have a peice of machined aluminum approximatley 1/2" pinned to their plate to space the starter to the front of the motor. I have two of those flexplates and have tried them, The starter drive is in the ring gear before it is even bolted up. The TCI would probably work if you spaced the starter back but I don't really like that idea. I tried calling JW but they are closed till Jan. 3rd.
I don't have anything out of the ordinary, 8 bolt crank and a 1/4" mid-plate.
Thanks, Joe Davis
Re: Anyone running a Reid powerglide [Re: jafr] #1145528
12/28/11 12:14 AM
12/28/11 12:14 AM
Arizona
Chris'sBarracuda Offline
Arizona
Not that difficult.
I believe that is/was the Dedenbear case.
You can call Hughes Performance..
http://www.hughesperformance.com/index.p...9&Itemid=61
Chris..
Re: Anyone running a Reid powerglide [Re: Chris'sBarracuda] #1145529
12/28/11 01:08 AM
12/28/11 01:08 AM
Southern IL.
jafr Offline OP
jafr  Offline OP
Southern IL.
Thanks Chris, I'll give them a try tomorrow.
Re: Anyone running a Reid powerglide [Re: jafr] #1145530
12/28/11 01:55 AM
12/28/11 01:55 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
Reid is the Dedenbear, you might look at ATI for flex plate/adapter. they're expensive but they make nice parts. afaik all of these setups use some sort of adapter on the crank to locate the converter and give proper spacing. what type of starter setup does the Reid use?
Re: Anyone running a Reid powerglide [Re: jamesc] #1145531
12/28/11 06:09 AM
12/28/11 06:09 AM
Southern IL.
jafr Offline OP
jafr  Offline OP
Southern IL.
The Reid uses a starter setup similar to JW, drivers side and bolts to the bell.
Re: Anyone running a Reid powerglide [Re: jafr] #1145532
12/28/11 06:15 AM
12/28/11 06:15 AM
Poulsbo, WA
ChrisJohnston669 Offline
Poulsbo, WA
I used a JW Flexplate with my JW trans.
Re: Anyone running a Reid powerglide [Re: ChrisJohnston669] #1145533
12/28/11 10:02 AM
12/28/11 10:02 AM
Woodstock , Georgia
Mopar_racer_99 Offline
Woodstock , Georgia
I am running a Reid case, mopar bellhousing, with a 1/4 in mid plate. You need to use the Jw flex plate for their bellhousing and need to order from jw, the starter nose extention 4.95 and shims I think they were 5 dollars. Pm me if you want.
I have my motor and trans out right now, doing some winter updates.
John
8.72 @ 154.6 ,68 Charger 578ci 440-1s, 3000# w/drvr, 2150 den/alt NA
Re: Anyone running a Reid powerglide [Re: Mopar_racer_99] #1145534
12/28/11 11:20 PM
12/28/11 11:20 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
You have to have a JW starter extension and shims. A full 1/4" mid plate and a flywheel adapter made 1/4" thicker works well.
Re: Anyone running a Reid powerglide [Re: Leon441] #1145535
12/31/11 10:29 AM
12/31/11 10:29 AM
Southern IL.
jafr Offline OP
jafr  Offline OP
Southern IL.
Ok I have a JW wheel ordered part $ 93010-c I believe. I have the crank adapter and shim kit so hopefully I can make some noise next week. Thanks for all your help guys, Joe Davis
Re: Anyone running a Reid powerglide [Re: jafr] #1145536
01/02/12 10:45 AM
01/02/12 10:45 AM
Southern IL.
jafr Offline OP
jafr  Offline OP
Southern IL.
I have the transmission installed and running.
I ended up using a JW wheel for an ultra bell with the JW crankshaft adapter. I also used .130 shim for the starter, instead of stacking shims I used a JW shim for a pattern and cut one out with a plasma cutter. I did not have to use the starter extension, the starter still fits into the register on the Reid bell.
The starter sounds great, the alignment is far superior to the adapter plate that I was using.
The only problem I had with instalation was that the bell is quite a bit wider than the stock powerglide because of the kick-out for the starter. When installing I had to roll the trans on it's side to get it up through the frame rails, this makes it a two person job.
In my opinion the Reid case and bell is a very nice piece and is a better option than the adapter plate setup. First you won't have to deal with a glide case that is at least 40 years old and prone to cracking, second no external shields to deal with, third the bell bolts to the case not the pump and the starter alignment is great.
I hope this helps someone in the future.
I Really appreciate the help from all the people that posted replys to this thread, especially John.
Joe Davis
Re: Anyone running a Reid powerglide [Re: jafr] #1145537
01/04/12 10:43 AM
01/04/12 10:43 AM
ky
68roadrunner Offline
ky
good to know Joe, it should fit right behind my jw bell and wheel.good luck this summer, see you then.lee
