Re: who has pushed the rear back on a dart for tire room [Re: ALKYW5DART] #1144491
12/26/11 11:36 PM
12/26/11 11:36 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Mine is moved back 1"
what size tire are you running and any better pics of side view thanks
29.5X 10.5. no sorry
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: who has pushed the rear back on a dart for tire room [Re: MR_P_BODY] #1144492
12/26/11 11:37 PM
12/26/11 11:37 PM
mo
ALKYW5DART Offline OP
mo
i need to push my rearend back on my 71 dart for tire clearence, who has done this and does it affect traction or should i cut the rear quarter in front of tire and keep rearend in stock location thanks guys
How much do you need to move it
about 3/4 of an inch
You can put 3/4" plates in front of your front hangers
and then (if you want) put a set of sliders on the
rear to eliminate the shackles... it wont hurt your
weight distribution bad enough to hurt in traction
mine has the spring relocation kit done i am trying to fit a 30.5x11.0 on a 12" wheel, i would have to weld up the hole on the rearend perch and redrill 3/4" forward . i talked to caltracs they said it wouldn't hurt anything if i did it that way thanks guys
Re: who has pushed the rear back on a dart for tire room [Re: bigtimeauto] #1144493
12/27/11 12:07 AM
12/27/11 12:07 AM
Down South
DaKuda Offline
DaKuda  Offline
Down South
I could be wrong but it looks to me like the quarter panel on your car has been cut as well as the rear moved back...?
Re: who has pushed the rear back on a dart for tire room [Re: MR_P_BODY] #1144494
12/27/11 12:09 AM
12/27/11 12:09 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Before I mini tubbed mine I had a 1/2" plate sandwiched between the hanger and mount. Any more will require the studs be knocked out and longer bolts used. When I mini tubbed mine I moved it back 1", it looks much better than before with the tire more centered. It's gone 1.38 60' with a pump gas small block, so I wouldn't worry about giving up anything.
Re: who has pushed the rear back on a dart for tire room [Re: justinp61] #1144495
12/27/11 01:14 AM
12/27/11 01:14 AM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
when i got my car painted i moved the front of my wheel wells front.
we cut from the middle of the wheel well up to the body line on the duster then front to the door. we could get away with cutting about 1 1/4" off the front of the piece we cut out. then rewelded it in ans welded in a piece on top of the wheel well to make up the amount it moved front. with 6.5"back space and the wells moved into the frame i have 30"x 10.5 slicks under the car.
Re: who has pushed the rear back on a dart for tire room [Re: dmking] #1144496
12/27/11 01:52 AM
12/27/11 01:52 AM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Wouldnt the best way to move everything back be a plate (like pictured above in the link) to move the rear back on the springs and make the front segment longer? Rather than simply moving the front mount back and creating potential problems in the rear mount geometry?
Re: who has pushed the rear back on a dart for tire room [Re: Hot 340] #1144497
12/27/11 04:38 AM
12/27/11 04:38 AM
Have you looked at the rear shackle angles on any stock A bodys they are not real good from the factory for drag racing, there almost straight up and down when sitting still Moving the spring back increases that angle in a positive manner I have put a 1/2 inch spacer in between the rear shackle hangar and the sub frame to make that angle better with the SS springs in the stock location
Re: who has pushed the rear back on a dart for tire room [Re: Cab_Burge] #1144498
12/27/11 10:56 AM
12/27/11 10:56 AM
bigfork mn
dragram440 Offline
dragram440  Offline
bigfork mn
You have to move the back accordingly with the front to keep the angles correct.
67' charger 499 RB 10.57 at 127
Re: who has pushed the rear back on a dart for tire room [Re: Hot 340] #1144499
12/27/11 11:24 AM
12/27/11 11:24 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
This is how I got the last 1/2" I needed. I redrilled the wholes in the spring buckets years ago to fit 28/12.5/15 Quick time pros and then offset the mount like in the picture to get a 295/65/15 drag radial in there. You will have a problem with a factory wheel tub fitting a 30" tall tire will hit at the back of the tub. I think a 29.5 is the tallest you can fit with getting out a hammer or cutting out some metal on the facory wheel tub. This is a front to back issue not a side to side issue.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: who has pushed the rear back on a dart for tire room [Re: 1967dartgt] #1144500
12/27/11 01:42 PM
12/27/11 01:42 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
I used a E-body front hanger, just had to drill the hole out a-little bit and it was right at an inch longer. It worked great and put the wheel in the center of the wheel well.
Re: who has pushed the rear back on a dart for tire room [Re: Hot 340] #1144501
12/27/11 01:49 PM
12/27/11 01:49 PM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
Who Sells those? I am using an A body rear end in my 51 and need to move it back an inch or so for a little more tire clearance. That looks like just the ticket.
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: who has pushed the rear back on a dart for tire room [Re: 70dusterjohn] #1144502
12/27/11 02:06 PM
12/27/11 02:06 PM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
I ordered my CalTrac monoleafs drilled to locate the axle 1" back. The car hooks great with no issues.
Re: who has pushed the rear back on a dart for tire room [Re: 70dusterjohn] #1144503
12/27/11 02:32 PM
12/27/11 02:32 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Never thought of that. Brillant!
Re: who has pushed the rear back on a dart for tire room [Re: GTSDave] #1144504
12/27/11 03:25 PM
12/27/11 03:25 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
-Dave
Afco sells a adj set, I just had a set made out of billet alum.
Re: who has pushed the rear back on a dart for tire room [Re: ALKYW5DART] #1144505
12/27/11 04:31 PM
12/27/11 04:31 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
For those of you who did move your axle back 1" AND run a stock fuel tank, is the clearance between the back of the axle housing and the tank a bit cozy? Contemplating moving one on a future build and running a Dana 60 - wondering if the rear axle cover will hit the stock fuel tank or sending unit, etc...
Re: who has pushed the rear back on a dart for tire room [Re: Sixpak] #1144506
12/27/11 04:42 PM
12/27/11 04:42 PM
organ
maximum entropy Offline
organ
i stretched my fenders discreetly and moved it forward. i figured, hey, i'm gonna move my axle to make my weight distribution worse? nah, i'll move it FORWARD. one of the best moves i made on the ol' scamp.
