Re: who has pushed the rear back on a dart for tire room
[Re: bigtimeauto]
#1144493
12/27/11 12:07 AM
12/27/11 12:07 AM
Posts: 1,015 Down South
DaKuda
Down South
Mine is moved back 1"
what size tire are you running and any better pics of side view thanks
29.5X 10.5. no sorry
I could be wrong but it looks to me like the quarter panel on your car has been cut as well as the rear moved back...?
[Re: Cab_Burge]
#1144498
12/27/11 10:56 AM
12/27/11 10:56 AM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
You have to move the back accordingly with the front to keep the angles correct.
67' charger 499 RB
10.57 at 127
[Re: Hot 340]
#1144501
12/27/11 01:49 PM
12/27/11 01:49 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
Wouldnt the best way to move everything back be a plate (like pictured above in the link)
Who Sells those? I am using an A body rear end in my 51 and need to move it back an inch or so for a little more tire clearance. That looks like just the ticket.
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: 70dusterjohn]
#1144503
12/27/11 02:32 PM
12/27/11 02:32 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
I used a E-body front hanger, just had to drill the hole out a-little bit and it was right at an inch longer. It worked great and put the wheel in the center of the wheel well.
Never thought of that. Brillant!
[Re: Sixpak]
#1144506
12/27/11 04:42 PM
12/27/11 04:42 PM
Posts: 5,080 organ
maximum entropy
organ
i stretched my fenders discreetly and moved it forward. i figured, hey, i'm gonna move my axle to make my weight distribution worse? nah, i'll move it FORWARD. one of the best moves i made on the ol' scamp.
