Re: 440 W8 Duster's k member
[Re: 440W8 Duster]
#1144072
04/17/12 03:17 PM
04/17/12 03:17 PM
Posts: 251 SD USA
neonic
SD USA
I got it in just checking stuff on it Scotty nice stuff.Cant wait to go to the track.
So your actually coming to the track this year? No more racing against the Neon, she's long down the road.
[Re: 440W8 Duster]
#1144075
04/24/12 09:45 AM
04/24/12 09:45 AM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
here's the old ride height.
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
[Re: 440W8 Duster]
#1144078
04/24/12 09:49 AM
04/24/12 09:49 AM
440W8 Duster
San Antonio,TX
front not to good of picture
[Re: J_BODY]
#1144080
06/27/12 01:25 AM
06/27/12 01:25 AM
440W8 Duster
San Antonio,TX
Car is ready will go out this weekend in Minot.
[Re: Dustedu]
#1144084
06/27/12 10:34 AM
06/27/12 10:34 AM
Posts: 3,699 Newport, Mi
Evil Spirit
Newport, Mi
I like the looks of that double crossbar style A LOT more than the single crossbar stuff that almost every one else makes. I think that would help keep the front frame rails square a lot better than a single tube. And no square tubing - BIG BONUS in the looks department. ![](/ubbthreads/images/graemlins/thumbs.gif)
Free advice and worth every penny... Factory trained Slinky rewinder.........
[Re: Evil Spirit]
#1144085
06/27/12 11:53 AM
06/27/12 11:53 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
Are you forgetting about that huge chunk of metal called the radiator support?
The double tube also limits a lot of great oil pan options. If you are running an otherwise stock street car with just a K-member change the extra cross tube may make you feel better. This may be give some advantage for a road course car. The frame rails are trying to be twisted from the coil over shock mounts in these coilover rack steering conversions. When mopar designed the front the weight of the car was on the torsion bar crossmember and we know how strong a materail that is. For any of these aftermarket suspensions to work the car really needs the forward bars from firewall or cage to front frame. Just my opinion.
Leon
