replace it
the fan will be left hand thred also
take out the 6 or 7 bolts that hold the alum bracket that mounts the a/c and alt,lift it and swing it over out of the way
then r&r the water pump,check the thermo housing they are good for rusting away on the neck
you can get at the sensors and heater hose while you are there
remember to put sealer and Tighten the heater hose nipple that goes in the water pump,and grease the o ring on the other heater pipe that goes in the pump
IMO if you got it down that far might as well r&r the t chain and front seal,sb are hard on the chain and it will have slop in it
rock the fan at the bearing to see if the clutch has slop and replace as needed
have fun and good luck
