This is my 2-cents (opinion), FWIW.
The lash is a large function of how the beginning and end ramps on the lobe were shaped (ground). That being said, some variation is tolerable. I wouldn't run a cam speced at 0.016" lash at 0.028" for any length of time (just a test). And a cam designed for 0.028" I would like to make no tigher than about 0.020"
On that particular grind (MP .557"), many people have run them around 0.024-0.026".
One other consideration. The lash will change as the engine heats up.
- Exhaust valve might need 0.002" more lash for the same ramp
- iron block, iron heads cause lash to tighten with heat
- iron block, aluminum heads cause the lash to loosen with heat, typically 0.004-0.005"
- aluminum block, aluminum heads and you might see 0.020" change from 50F to 200F.
