1998 dodge ram v10 fuel filter #1143075
12/24/11 10:40 AM
12/24/11 10:40 AM
Salem, VA
JRMOPAR Offline OP
JRMOPAR  Offline OP
Salem, VA
I'm embarrassed to ask this but....my 98 Ram 3500 Dually has been stallng out at idle sometimes, usually after warming up. I am guessing fuel filter but where is it located? Local parts store had it listed as "non-seviceable"?
Re: 1998 dodge ram v10 fuel filter [Re: JRMOPAR] #1143076
12/24/11 10:41 AM
12/24/11 10:41 AM
st.cloud fl
d-150 Online content
Smarter than a 5th grader?
d-150  Online Content
st.cloud fl
in the tank
Re: 1998 dodge ram v10 fuel filter [Re: d-150] #1143077
12/24/11 11:23 AM
12/24/11 11:23 AM
tulsa ok
U
upnover Offline
upnover  Offline
U
tulsa ok
in the tank
Re: 1998 dodge ram v10 fuel filter [Re: upnover] #1143078
12/24/11 12:56 PM
12/24/11 12:56 PM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Its part of the pump unit. There is a primary filter on the bottom that could be a nylon screen or a round paper unit. Then there is a secondary unit on top thats silver which is what the fuel line hooks to. This is also the pressure regulator. To do them, the pump needs to come out. If you have some miles on it, you would be better off replacing the pump module instead of just the filters [ the nylon unit can't be replaced anyway]. Also put a new fuel pump relay in. If the old one is sketchy, it will take the new pump out due to lack of voltage. I learned this the hard way. I'm more inclined to think you need to clean the throttle body and A.I.S. or I.A.C. motor since these being dirty will cause stall issues too. Get a tb gasket, some Berrymans and an old toothbrush and have a scrub party.
Carl Kessel
Re: 1998 dodge ram v10 fuel filter [Re: CKessel] #1143079
12/24/11 02:31 PM
12/24/11 02:31 PM
Salem, VA
JRMOPAR Offline OP
JRMOPAR  Offline OP
Salem, VA
yeah the throttle body was my first thought as well since i have had to clean the ones on our v6's for years (92 3.0 acclaim and 96 3.8 T&C) so i'll try that plus a couple cans of sea foam and see what happens...thanks...
Re: 1998 dodge ram v10 fuel filter [Re: JRMOPAR] #1143080
12/24/11 03:08 PM
12/24/11 03:08 PM
Ozona, Texas
P
Paladin Offline
Paladin  Offline
P
Ozona, Texas
JR,
Unless you have uncommonly good luck when placing a bet, why don't you see if you can locate a scan tool and see what it tells you? I bought my V10 some six months ago, and the first two purchases made for it were a scan tool and a shop manual.
With these newer vehicles these two items are a must have in both cost effectiveness as well as time and effort expended.
Hope the problem is found quickly and easily repaired.
Merry Christmas,
Paladin
1971 Dodge Charger R/T
1977 Chrysler Cordoba A35
1979 Dodge Lil� Red Express
1981 Chevrolet Corvette
1985 Chevrolet Corvette
1986 Chevrolet Corvette Roadster
1994 Lincoln Mark VIII
1998 Dodge Ram 2500 Sport V10
