Tires & rims.! How big can i go. #1142793
12/23/11 11:40 PM
12/23/11 11:40 PM
Maryville tn
67coronetman Offline OP
Maryville tn
I have a 1966 plymouth satellite springs still in factory location i have 15 x 7 steel rims with a 4.5 back spacing whats the biggest tires i can put on the back & front.!
Old car are me......
Re: Tires & rims.! How big can i go. [Re: 67coronetman] #1142794
12/23/11 11:46 PM
12/23/11 11:46 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Is there a question somewhere in there? Its a bit hard to tell.
Re: Tires & rims.! How big can i go. [Re: Kern Dog] #1142795
12/23/11 11:49 PM
12/23/11 11:49 PM
Maryville tn
Maryville tn
Yes read what it says i am asking.!
Re: Tires & rims.! How big can i go. [Re: 67coronetman] #1142796
12/24/11 12:11 AM
12/24/11 12:11 AM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
It's been a long time, but I had 245-60's all around on mine from memory. Was hard to fit anything really wide out back I seem to think? (a 255 maybe?)
Of course now a days I would go with something modern in 17" or 18"
Re: Tires & rims.! How big can i go. [Re: 67coronetman] #1142797
12/24/11 12:20 AM
12/24/11 12:20 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I have a 1966 Plymouth Satellite with springs still in the factory location. I have 15 x 7 steel rims with a 4.5 back spacing. Whats the biggest tires I can put on the back & front ?
There you go. You're welcome.
Re: Tires & rims.! How big can i go. [Re: Kern Dog] #1142798
12/24/11 05:15 AM
12/24/11 05:15 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Honestly a tapr measure and a piece of chalk is your best way to find out..
Keep atleast a 1/2" clearance from the wheel lip and the springs.
I am truckless..
Re: Tires & rims.! How big can i go. [Re: 340SHORTY] #1142799
12/24/11 10:56 AM
12/24/11 10:56 AM
Indiana
O
Osyman Offline
Osyman  Offline
O
Indiana
15x7 4.5in back space 255/60-15 on back perfectly centered with a little less than an inch clearance on each side.
235/60's on the front. Tires are indy 500's
Re: Tires & rims.! How big can i go. [Re: 67coronetman] #1142800
12/24/11 12:15 PM
12/24/11 12:15 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you can get a 275/60/15 out back and I'd run a 215/75/15 or 225/70/15 up front.
Coming soon!!!!
Re: Tires & rims.! How big can i go. [Re: Mr.Yuck] #1142801
12/24/11 08:57 PM
12/24/11 08:57 PM
Maryville tn
Maryville tn
Yes i was able to run the 275/60/15 out back but i needed to trim about 1/2 inch of the Inner wheel lip. Plus i used a 15 x 7 steel rim with a 4.5 inch offset i had to let out the air & work them in but they fit and the back off the tire near the spring has just at a 1 inch spacing & the front of the wheel opening there is just over 1 1/4 inch of space.
The fronts i ran 245/60/15 on steel rims. the car handles way better than it did before.
Thanks for all your replies was helpful.
