2006 Pacifica PS diagnosis help #1142460
12/23/11 01:55 PM
12/23/11 01:55 PM
We don't make mistakes...
67500vert Offline OP
06 Pacifica, 3.5, AWD, 54k miles with intermittant PS problem
When cold the steering acts as if the engine had cut out, very hard to turn, does not last long and is gone after a minute of warm up. Does *not* happen all the time. PS fluid level is good.
Could it be:
1) belt (does not look worn or cracked)
2) belt tensioner
3) pump
4) rack
5) something else?
67 Coronet 500 Convertible Nemo me impune lacessit
Re: 2006 Pacifica PS diagnosis help [Re: 67500vert] #1142461
12/23/11 02:48 PM
12/23/11 02:48 PM
Space Station #5
471Magnum Offline
471Magnum  Offline
Space Station #5
typical rack and pinion failure
-Jim
I can fix it... my old man is a television repairman.
He's got the ultimate set of tools... I can fix it.
Currently Mopar-less
