Page 2 of 3 1 2 3
Re: RPM users, care to share tips/ experiences? [Re: burdar] #1142095
12/23/11 11:31 PM
12/23/11 11:31 PM
I really like the look of the new packaging. I'm not a fan of the plastic container. It looks kind of cheap and the inner section spins inside the outer shell when I screw the lid back on. I have no complaints with the product itself.
Hi Darren,
Thanks for the feedback on the container, we were seeing the same thing on some containers. I think you will find the new container more robust. It's made of a different,stronger material and is a single wall construction vs the old two piece. Combine it with the new metal lid and you won't see any dimensional change in the container. The new container rolls into production next week.
Re: RPM users, care to share tips/ experiences? #1142096
12/24/11 12:02 AM
12/24/11 12:02 AM
jersey shore
flypaper Offline
I hate Texas
flypaper  Offline
I hate Texas
jersey shore
i decided to try it out and i just put a order in for some a few days ago..
i wonder if i will get the old or new packaging?
Re: RPM users, care to share tips/ experiences? [Re: flypaper] #1142097
12/24/11 09:50 AM
12/24/11 09:50 AM
SE Pa.
LimeliteAero Offline
SE Pa.
Im curious as to why anyone would apply it on painted parts? Whats the goal?
Re: RPM users, care to share tips/ experiences? [Re: LimeliteAero] #1142098
12/24/11 10:33 AM
12/24/11 10:33 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I think the main issue is with inspection marks. Since you can't paint over RPM, you have to reapply the inspection marks before hand. I havn't had any issues with RPMing over the paint.
The RPM should also add a layer of protection to the paint. If the paint isn't applied very thick your part could start rusting again. Applying the RPM over the paint would protect against that.
Re: RPM users, care to share tips/ experiences? [Re: burdar] #1142099
12/24/11 11:42 AM
12/24/11 11:42 AM
K
kielbasa Offline
kielbasa  Offline
K
I am currently restomodding my AAR and have been using the stuff on all the natural pieces. We'll see how it holds up and prevents corrosion, seems awesome so far! I have been spending a lot more time in the kitchen lately (using wifey's oven and cookie sheets) - preheat my parts to 180~200 degF and have fun brushing parts with the kids.
Make sure you have good light to work with, much easier to see if the workpiece receives complete coverage, easy to miss a spot if you have poor lighting.
Re: RPM users, care to share tips/ experiences? [Re: kielbasa] #1142100
12/24/11 12:11 PM
12/24/11 12:11 PM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
this might sound silly but i gotta ask. how do you know when the to-be-treated object is hot enough. the instructions say 120 but is that just a 'close enough' number? can you tell by how it flows?
Re: RPM users, care to share tips/ experiences? [Re: kielbasa] #1142101
12/24/11 02:13 PM
12/24/11 02:13 PM
London, England
Gavin Offline
Gavin  Offline
London, England
I have to ask - doesn't this stink the kitchen out? If not then I will do this myself - I had a problem doing my steering box, couldn't get the whole thing warm enough and ended up applying to a small area at a time and using the heat gun - but I don't think this has really achieved the job, I think I need to heat it all up and it will melt properly and leave the finish I've achieved on smaller parts.
Re: RPM users, care to share tips/ experiences? [Re: Gavin] #1142102
12/24/11 02:34 PM
12/24/11 02:34 PM
K
kielbasa Offline
kielbasa  Offline
K
RPM will stink the kitchen up if i do bigger pieces, so i learned to take the pieces out of the oven (with her oven mitts) and go into garage quickly before part cools off.
now if you begin putting dirty, greasy parts in the oven, THEY may stink the kitchen up - i have so far only been baking sandblasted, cleaned parts which have no odor.
i will be in a dilemna when i have to do "dirty" parts - then i may have to invest in an old oven to put in the garage.
i also found that the RPM works best when i have the oven preheated to 200 degF, if i set it at 180 it's marginal.
Re: RPM users, care to share tips/ experiences? [Re: kielbasa] #1142103
12/24/11 02:43 PM
12/24/11 02:43 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I bought a cheap old garage sale oven ($25 bucks and works like a charm!) and keep it in back of the shop for such jobs. Plus, added bonus....I have no wife to worry about
Re: RPM users, care to share tips/ experiences? [Re: mikemee1331] #1142104
12/24/11 02:45 PM
12/24/11 02:45 PM
Hi Everyone,
I'm seeing a lot of great questions about RPM. I'll try and give the short version on a couple I have seen.
1. How hot does the part need to be?
We recommend above 120 degrees. After you practice on a test piece you'll find the ratio of heat to product flowing.When the part is warmed you will notice that RPM flows when applied. I use a heat gun but we have people who have used hair dryers, ovens, radiant heat, even putting the part out in the sun during the summer. I don't recomment torches or flame type heat since we don't need the part glowing red and most flames will leave residue and soot. On large pieces you can work in sections. We treated the driveshaft by heating about a 12-18 inch section and working from one end to the other. Remember always wear appropiate protection when handling warmed parts. Don't forget adequate ventilation.
2. Painting over RPM.
Most paint manufacturers recommend natural clean surfaces for adhesion. If you oiled a part then tried to paint over it you wouldn't get great results. Even painting some paints over other paints isn't satisfactory ( laquer vs enamel).
3. RPM over paint.
RPM will provide an additional layer of protection. As pointed out above sometimes you see corrosion on painted parts. I recently treated a K-Frame on a late model builder project for additional protection. Most paints will withstand the normal heat range that you use to apply RPM
All great questions. Thanks for everyone passing on their own personal techniques.
Merry Christmas and Happy Holidays.
Re: RPM users, care to share tips/ experiences? [Re: mikemee1331] #1142105
12/24/11 02:55 PM
12/24/11 02:55 PM
K
kielbasa Offline
kielbasa  Offline
K
i found that the temp is warm enough when the RPM looks "wet" once you brush it on - it brushes on granular if not warm enough.
Re: RPM users, care to share tips/ experiences? [Re: kielbasa] #1142106
12/26/11 03:49 PM
12/26/11 03:49 PM
Great tip !
I find it works good to have the heat gun in one hand and the RPM brush in the other. Use the heat as needed to keep the surface temp up so the product flows when applied. RPM goes on glossy which helps you verify you get complete coverage then dries to a satin finish. RPM can also be reheated once applied to blend in or remove excess product.
Using the heat gun for a quick blast( 2-3 seconds) into the RPM container will soften the product if you feel you need to apply a larger amount. We have found that heating the part works best for application so it flows when applied. Different metals retain heat differently ( a cast part with more mass vs a sheet metal part cool at differnt rates)
Does anyone have any non automotive uses for RPM?
Re: RPM users, care to share tips/ experiences? #1142107
12/27/11 02:51 AM
12/27/11 02:51 AM
ILLinois
DartGTS Offline
super street
DartGTS  Offline
super street
ILLinois
Hello:
I been following this product for a while now and thinking about ordering some to use on my son's 68 Road Runner.
Apparently the part has to be heated for proper
adhesion...then can be reheated if need to make a change on it.
My question which may already be answered...How well does it stand up in a hot engine compartment..or if used on hot parts such as exhaust manifolds??
Regardless of the answer I will probaly order anyway....looks to good to pass up on for much longer.
Maynard
Re: RPM users, care to share tips/ experiences? [Re: DartGTS] #1142108
12/27/11 03:55 AM
12/27/11 03:55 AM
Hi Maynard,
Heating the part allows RPM to flow out when applied with the brush( which we supply with the product). A heat gun or hair dryer will provide enough heat to warm the part. We have used RPM on the head pipe of Project Valiant for corrosion protection. Exhaust manifolds are a completely different heat profile approaching 1000 degrees and while we haven't tested this area I would have reservations.
We have several people reporting they have used RPM on aluminum carbs ( AVS-AFB) to prevent that white corrosion on aluminum. RPM works great on suspension, cast and stamped parts plus sheet metal in the bare areas under the dash and shelf panel. Got a set of non coated aluminum wheels? It works great to retain that polished look that goes away so quick with out protection.
Thanks for the question
PS - always great to have a shout out to a fellow GTS owner( LS27P9B)
Re: RPM users, care to share tips/ experiences? #1142109
12/27/11 09:40 AM
12/27/11 09:40 AM
ILLinois
DartGTS Offline
super street
DartGTS  Offline
super street
ILLinois
Hello Tom:
Yeah I had my doubts about the exhaust manifolds. I might have tried it, but thats not my favorite part to redo if it don't work out. LOL
However I do have an older pair or Ansen Slot Mags (5on4 7x14)I been thinking of cleaning up and selling might give it a shot on them.
OK on the GTS owners we got the best of the Darts.
Maynard
Re: RPM users, care to share tips/ experiences? [Re: DartGTS] #1142110
12/29/11 12:49 PM
12/29/11 12:49 PM
Sweden
71redcuda Offline
71redcuda  Offline
Sweden
Im thinking i maby could use RPM on the clamps/heads of the battery cables..
Have anyone tried?
What color/shade should the heads have from factory?
Are the heads made of bare metal or did they have some kind of coating or other material?
If i clean them off with steel wool and then put on the RPM i afraid to get a wrong shade/color on the heads..
I want it to look original.
Nicklas
Re: RPM users, care to share tips/ experiences? [Re: 71redcuda] #1142111
01/06/12 01:24 AM
01/06/12 01:24 AM
Reno, Nevada
NV69B7RR Offline OP
NV69B7RR  Offline OP
Reno, Nevada
How do you remove RPM from metal?
Re: RPM users, care to share tips/ experiences? [Re: NV69B7RR] #1142112
01/06/12 10:23 PM
01/06/12 10:23 PM
cataclysm80 Offline
cataclysm80  Offline
possibly paint stripper or lacquer thinner, but since you can't see RPM after proper application, it would be difficult to tell if you got it all off. Maybe try one of those hot caustic tanks that machine shops use? Any other ideas?
Tav
Re: RPM users, care to share tips/ experiences? #1142113
01/06/12 10:28 PM
01/06/12 10:28 PM
cataclysm80 Offline
cataclysm80  Offline
Hi
My great uncle bought a V8 Ford in 1938. We don't drive it very often, and the inside of the fuel pump filled up with that white corrosion stuff. It's an aluminum pump that comes apart into two halves with a rubber diaphram in between. Could I use RPM inside the fuel pump?
Is RPM fuel resistant? (I'm guessing so if they're using it on carbs, but maybe they're only using it on the outside?)
Tav
Re: RPM users, care to share tips/ experiences? [Re: cataclysm80] #1142114
01/07/12 05:52 AM
01/07/12 05:52 AM
midwest
68427vette Offline
68427vette  Offline
midwest
do MOPARTS members get a discount???
i sandblast for several hot rod/resto shops , i cant wait to get some!!
do you have a distributor in columbus ohio? home of mopars..
jc
Page 2 of 3 1 2 3
