REPLACEMENT VALVE COVER GASKETS #1142024
12/22/11 10:46 PM
12/22/11 10:46 PM
Texas, USA
68cuda2003 Offline OP
Texas, USA
I need to replace the valve cover gaskets on my Indy EZ heads and Indy valve covers. I tried the Felpro fiber and they still leaked. Any better ideas? Would like to purchase the reuseable ones so I can adjust the valves without replacing them every time. Thanks. Ken
Re: REPLACEMENT VALVE COVER GASKETS [Re: 68cuda2003] #1142025
12/22/11 10:49 PM
12/22/11 10:49 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
moroso has nice silicone gaskets. i use them on my sb. no leaky. merryxmas, seeya.
Re: REPLACEMENT VALVE COVER GASKETS [Re: rickraw] #1142026
12/22/11 10:54 PM
12/22/11 10:54 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Re: REPLACEMENT VALVE COVER GASKETS [Re: WILD BILL] #1142027
12/22/11 11:53 PM
12/22/11 11:53 PM
Mo.
racerx Online work
racerx  Online Work
Mo.
Bill do no if they sell the intake gaskets 4 the -1?...thax
Re: REPLACEMENT VALVE COVER GASKETS [Re: racerx] #1142028
12/23/11 12:15 AM
12/23/11 12:15 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Sorry, I don't know.
PM Roadhazard.
https://board.moparts.org/ubbthreads/show...hat=showmembers
He's the one that makes em
Re: REPLACEMENT VALVE COVER GASKETS [Re: racerx] #1142029
12/23/11 12:20 AM
12/23/11 12:20 AM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
Yes, there are -1 intake gaskets available in both thickness'. Let me know if you need some or information on them.
RIP Monte Smith
Re: REPLACEMENT VALVE COVER GASKETS [Re: WILD BILL] #1142030
12/23/11 12:40 AM
12/23/11 12:40 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
http://www.superformanceproducts.com/
Been using and re-using mine for quite a while........THE best gaskets I`ve ever used and the Morosos suck.......air and leak oil.
Re: REPLACEMENT VALVE COVER GASKETS [Re: CompWedgeEngines] #1142031
12/23/11 09:18 AM
12/23/11 09:18 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
Thax's Todd i'll b giveing u a ....
Re: REPLACEMENT VALVE COVER GASKETS [Re: racerx] #1142032
12/23/11 10:59 AM
12/23/11 10:59 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
68cuda2003 I believe Competition Wedge has these in stock. Todd is great to work with so give him a or a PM
If these are not The Best Valve Cover Gaskets you've ever used on that motor I'll personally GIVE YOUR MONEY BACK!
Racerx, Competition Wedge carry's my complete line and we Thank You for your support
Thanks again Wild Bill
Thumper, a BIG thanks to you to
Competition Wedge thanks for all you do
Merry Christmas!
Greg
Re: REPLACEMENT VALVE COVER GASKETS [Re: roadhazard] #1142033
12/23/11 12:20 PM
12/23/11 12:20 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
Anyone have any pictures since the site doesn't?
I've been using the moroso rubber coated steel shim ones and I see that Cometic is making similar ones now.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: REPLACEMENT VALVE COVER GASKETS [Re: WadeMetzinger] #1142034
12/23/11 12:26 PM
12/23/11 12:26 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I have tried numerous gaskets, the moroso's were the worst for leaks, they split around the steel band, put the superperformance ones on, end of problem.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: REPLACEMENT VALVE COVER GASKETS [Re: WadeMetzinger] #1142035
12/23/11 01:06 PM
12/23/11 01:06 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Thanks Mick
Wade
Sorry the site isn't done yet, not enough hours in the day
Here's a pic FWIW. These are made from a very flexible premium long lasting material.
Re: REPLACEMENT VALVE COVER GASKETS [Re: deaks] #1142036
12/23/11 02:37 PM
12/23/11 02:37 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Mick
Had the same problem. Got some gaskets off of Roadhazzard an problem solved! Moroso Gaskets
Re: REPLACEMENT VALVE COVER GASKETS [Re: roadhazard] #1142037
12/23/11 03:44 PM
12/23/11 03:44 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Merry Christmas!
Greg
You`re welcome............now if you would just hire me to help perfect those puppies, we could both get rich.
Re: REPLACEMENT VALVE COVER GASKETS [Re: roadhazard] #1142038
12/23/11 05:31 PM
12/23/11 05:31 PM
Super Scamp Offline
Super Scamp  Offline
Thanks Mick
Wade
If these are the gaskets that Moore &Moore (Jack) is selling at the track for 25 bucks they are off the hook.
They are thin but do the trick I use them on my Indy valve covers and they work great...
Just One Man's Opinion Mopar Mafia Racing
Re: REPLACEMENT VALVE COVER GASKETS [Re: Super Scamp] #1142039
12/23/11 06:50 PM
12/23/11 06:50 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Not sure about at the track but I did see Jack was selling Greg's gasket's @ the last mopar swap meet in Columbus.
Greg, don't mention it
Dom, Me first
Re: REPLACEMENT VALVE COVER GASKETS [Re: roadhazard] #1142040
12/23/11 10:01 PM
12/23/11 10:01 PM
Ontario, Canada
Hyper Henry Offline
Hyper Henry  Offline
Ontario, Canada
Merry Christmas!
Greg
I could use a couple sets, sick of those Moroso ones always leaking Will you ship to Canada
I sent a PM as well.
Derrick
Re: REPLACEMENT VALVE COVER GASKETS [Re: roadhazard] #1142041
12/24/11 11:06 AM
12/24/11 11:06 AM
Mo.
racerx Online work
racerx  Online Work
Mo.
Merry Christmas!
Greg
Any plans to make an exhaust gasket in the near future?
Re: REPLACEMENT VALVE COVER GASKETS [Re: WILD BILL] #1142042
12/24/11 12:14 PM
12/24/11 12:14 PM
Super Scamp Offline
Super Scamp  Offline
Dom, Me first
If you would take your junk to the track then you would of known..
Re: REPLACEMENT VALVE COVER GASKETS [Re: Super Scamp] #1142043
12/24/11 01:17 PM
12/24/11 01:17 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
Super Scamp thanks for the "Off The Hook" compliment glad you like them
racerx, no exhaust gaskets in the NEAR future. I have some other projects in line for 2012.
Hopefully some metering block, bowl and power valve gaskets for the 4150 and 4500 both 2 and 3 circuit
Wish I could do everything at once but you need to pay the bills as you go or
The more people spread the word, the more people buy, the more I can expand the product line.
Simple economics
MERRY CHRISTMAS!
Thanks everyone for your support!
Greg
