9" deck R3
#1141054
12/21/11 08:18 PM
12/21/11 08:18 PM
Posts: 84 Minnesota
Coldart
Minnesota
Will a 4" stroke crank fit in a 9" deck R3? If not what's the most that will fit? Thanks
Re: 9" deck R3
[Re: bdaz smblk]
#1141057
12/22/11 12:02 AM
12/22/11 12:02 AM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
9.00" deck 4.00" crank 6.00" rod 1.00" compression height piston with zero deck.
Re: 9" deck R3
[Re: 340_Dart]
#1141062
12/23/11 12:39 AM
12/23/11 12:39 AM
Posts: 437 south central pa
bdaz smblk
south central pa
It has always been a 4" stroke.
3120lb, small block, 10.5" tire, NA, through exhaust, full int, WITH 83/4 REAR, 9.0 at 150mph
