Page 1 of 6 1 2 3 4 5 6
NE1 else hearing that Diapers will be required on 10.99 #1140793
12/21/11 04:05 PM
12/21/11 04:05 PM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
I'm hearing that all NHRA tracks will be enforcing the rule that any car running 10.99 or faster must have a diaper? It was in the 2011 rule book that it will be enforced starting 2012.
I figured they would enforce it at NHRA Divisional and National events but not at the local track events but I'm hearing they will be enforcing it at all events.
It's supposedly tied to insurance, if someone wrecks and the track submits the costs to the insurance company but they didn't have a diaper, they won't cover any of the costs and I guess they could loose their insurace coverage...
It would be hard to swallow for 9.99 and faster but 10.99 and faster is going to be very hard to swallow. When the sport is fighting to keep car counts up, I think this will cause some to give up the sport and a lot of others to travel to non-NHRA tracks.
I think you can get a diaper for $150 - $200 but that's the easy part, I can't imagine putting one on a big block A-Body... trying to keep it off the headers, dealing with the drag link...
For my wife's car, I'll just slow it down to run 11.teens or so and since I don't have stock K-member it won't be that big of a deal for me but I expect this to be a big deal for a lot of racers this year.
What are you guys hearing?
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: WadeMetzinger] #1140794
12/21/11 04:21 PM
12/21/11 04:21 PM
DANBURY CT
fury62 Offline
fury62  Offline
DANBURY CT
one of our race track's stated, 9.99 or quicker in 2012. you must have an engine diaper.
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: WadeMetzinger] #1140795
12/21/11 04:44 PM
12/21/11 04:44 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
S/ST 10.90 cars must have a diaper this year,so expect the tracks to make any car running 10.90 or quicker to have a diaper.
Nautilus Racing-
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: Chris2581] #1140796
12/21/11 04:50 PM
12/21/11 04:50 PM
PA
moparacer Online content
moparacer  Online Content
PA
Well I am about to find out whatr its like in a 68 Dart with stock suspension and a big block....
Only thing I have going for me is fenderwell headers....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: WadeMetzinger] #1140797
12/21/11 05:18 PM
12/21/11 05:18 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I certainly hope not... or that's going to severely restrict the # of tracks I'm going to bother to drive the MoPig to.
Gimme an I!
Gimme an H!
Gimme an R!
Gimme an A!
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: BradH] #1140798
12/21/11 05:38 PM
12/21/11 05:38 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If this ends up the rule it will make my next engine alot cheaper!
68 Barracuda Formula S 340
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: Bad340fish] #1140799
12/21/11 05:49 PM
12/21/11 05:49 PM
Sidney,Ohio
challenger1320 Offline
Sidney,Ohio
All you guy pi$$ on moan about a diaper but when you toss a rod at the 1000' mark and drive thru your on oil, hit the wall or worse yet the guy in the other lane that 150.00 dollar diaper and the effort to install it will seem cheap. I think anything with slicks should have to have a diaper.
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: challenger1320] #1140800
12/21/11 06:36 PM
12/21/11 06:36 PM
BA, OK
O
orangedustya Offline
O
BA, OK
So you are saying its slicks that causes a car to drop a rod. The 13.50 car with slicks should have a blanket but the 13.50 car on street tires doesn't need one. Hmmm-interesting.
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: orangedustya] #1140801
12/21/11 06:53 PM
12/21/11 06:53 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
i know safety should be first, but how often are rods dropped. what about a flat at 1000'? u going to run runflat tires? seeya.
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: orangedustya] #1140802
12/21/11 06:54 PM
12/21/11 06:54 PM
Sidney,Ohio
Sidney,Ohio
What I am saying is if it is a race car but a diaper on it.
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: challenger1320] #1140803
12/21/11 07:02 PM
12/21/11 07:02 PM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
If this is the case, anybody want to buy a iron headed 448 incher?
I have a 225/6 I can just build. Sure would be less hassle
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: roadhazard] #1140804
12/21/11 07:11 PM
12/21/11 07:11 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
per 2012 rule book for Super Street.
OIL-RETENTION DEVICE
All vehicles must utilize an NHRA-accepted lower engine oil-
retention device; may use a belly pan in lieu of a device attached to
the engine. If belly pan is used, must extend from framerail to
framerail and extend forward of the harmonic balancer and
rearward to rear-engine plate and must incorporate a minimum 2-
inch-high lip on all sides. A nonflammable, oil-absorbent liner
mandatory inside of retention device. See General Regulations 1:8.
Tony
70 AARCuda Vitamin C
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: 70AARcuda] #1140805
12/21/11 07:13 PM
12/21/11 07:13 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
per 2012 rule book for super pro/ pro/ sportsman
All vehicles permitted to utilize an NHRA-accepted lower engine oil-
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: 70AARcuda] #1140806
12/21/11 07:14 PM
12/21/11 07:14 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
General Regulation 1.8
1:8 LOWER ENGINE CONTAINMENT DEVICE
In classes where specified, must utilize an NHRA-accepted lower
engine oil-retention device. SFI Spec 7.1 or 7.2 Lower Engine
Containment Device permitted. A properly fitting lower engine
ballistic/restraint device mandatory. The NHRA Technical staff can
accept or reject any device. Any device that fails to perform as
required must be replaced or repaired to the satisfaction of the
Technical staff prior to any further runs. When used, an SFI Spec
7.1 or 7.2 Lower Engine Containment Device must cover the sides
of the block and pan up to within one inch of the head mating
surface and extend to within 1 1/2 inches of the front and rear of the
cylinder case area. SFI Spec 7.1 devices must be
updated/recertified by the original manufacturer at one-year
intervals. In classes where specified, a belly pan may be used in
lieu of a device attached to the engine. The belly pan must extend
from framerail to framerail and extend forward of the harmonic
balancer and to the rear of the engine block and must incorporate a
minimum 2-inch-high lip on all sides unless specified in Class
Requirements. Minimum number of slots or holes in the walls to
clear frame, steering, or lines permitted. A nonflammable, oil-
absorbent liner mandatory inside of retention device.
Tony
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: challenger1320] #1140807
12/21/11 07:30 PM
12/21/11 07:30 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
From the 2012 NHRA rulebook (Available for download online at NHRA.com in the member section)
All vehicles running 7.49 or quicker must utilize an NHRA-accepted lower engine oil-retention device; may use a belly pan in lieu of a device attached to the engine. The belly pan must extend from framerail to framerail and extend forward of the harmonic balancer and rearward to rear engine plate and must incorporate a minimum 2-inch-high lip on all sides. A nonflammable, oil-absorbent liner mandatory inside of retention device. See General Regulations 1:8.
General Regulations Section 20, page 8
{read this carefully}In classes where specified, must utilize an NHRA-accepted lower engine oil-retention device. SFI Spec 7.1 or 7.2 Lower Engine Containment Device permitted. A properly fitting lower engine ballistic/restraint device mandatory. The NHRA Technical staff can accept or reject any device. Any device that fails to perform as required must be replaced or repaired to the satisfaction of the Technical staff prior to any further runs. When used, an SFI Spec 7.1 or 7.2 Lower Engine Containment Device must cover the sides of the block and pan up to within one inch of the head mating surface and extend to within 1 1/2 inches of the front and rear of the cylinder case area. SFI Spec 7.1 devices must be updated/recertified by the original manufacturer at one-year intervals. In classes where specified, a belly pan may be used in lieu of a device attached to the engine. The belly pan must extend from framerail to framerail and extend forward of the harmonic balancer and to the rear of the engine block and must incorporate a minimum 2-inch-high lip on all sides unless specified in Class Requirements. Minimum number of slots or holes in the walls to clear frame, steering, or lines permitted. A nonflammable, oil absorbent liner mandatory inside of retention device.
So a quick review of the book I found the following
Top Sportsman - required
Top Dragster - required
Super street - required
Super gas - required
Super comp - required
Comp - required
Super Pro, Pro, Sportsman - permitted - see gen. reg. 1.8
NOW for the fun part - Individual tracks can impose there own extra requirements for the season AND/OR special events. So if you you have a turbo car, NOS car, or small tire/overpowered car, I would recommend you look into a diaper for safety and to insure you meet possible rules.
It also looks like, unless your local track adds additional rules, as long as your not running division or national events you can run down to 7.50 without a diaper (not necessarily smart, but permitted).
LOL (Guess I was too slow)
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: ProStDodge] #1140808
12/21/11 07:55 PM
12/21/11 07:55 PM
Arizona
Chris'sBarracuda Offline
Arizona
The diaper is one of the NHRA safety rules I do agree with.
Lots of slower cars oiling down the tracks nowadays, ruining it for others.
Chris..
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: Chris'sBarracuda] #1140809
12/21/11 08:20 PM
12/21/11 08:20 PM
Super Scamp Offline
Super Scamp  Offline
I agree with the diaper rule completely I have 71 A body with BB 2" fenderwell headers. I run 9.0's at 150. My DRE 150.00 dollar diaper is not SFI approved but it does the job. Yes the headers did do a # on the top of the diaper, but I can get another year of racing out of it..
If the NHRA techs want me to upgrade to a SFI unit I will just pull it out of the trailer and install it in 20 min. It's not that hard to do.
Just One Man's Opinion Mopar Mafia Racing
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: Chris'sBarracuda] #1140810
12/21/11 08:24 PM
12/21/11 08:24 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i would be interested in seeing pics if anyone has them on their car now
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: Chris'sBarracuda] #1140811
12/21/11 08:29 PM
12/21/11 08:29 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
The only addition for next year will be S/ST. Many of the backhalfed cars that ran the class will be gone, reducing an already depleted car count.
Edgewater requires diapers for bracket cars faster than 6.40, Indy requires them for the Rage events.
Re: NE1 else hearing that Diapers will be required on 10.99 [Re: sixpackgut] #1140812
12/21/11 08:36 PM
12/21/11 08:36 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Me too, as I'm running stock front end and going to a new wedge this year. I have the drag link throught the pan, how the heck does that work. Is it a special order type and does that mean lots of Anyone have pics of one on an A-body I would like to see. Thanks
