Re: electrical help please
[Re: Tadams]
#1140183
12/20/11 05:48 PM
12/20/11 05:48 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Do you have power befor the dash, like in the bulk head connector, cigar lighter, interior lights? Might want to make sure you are getting power into the cab then try to find out where it is or isn't going. Kinda sounds like the fuseable link. It's a heavy (red?) wire coming out of the bulk head connector into the engine compartment. It will have a yellow tag that says fuseable link if still stock. If this goes you will have no power. Might have shorted something putting the gauge cluster in and out a lot.
I have mechanical Aptitude. I can screw up anything.
[Re: Tadams]
#1140185
12/20/11 06:17 PM
12/20/11 06:17 PM
Posts: 10,968 Hampton, Ga.
70dart360
Green Meister
Green Meister
Hampton, Ga.
Amp gauge may be whacking out, buypass it and try it again.
70 Dart Swinger
72 D-100 440 shortbed
76 Pinto, 68k 21mpg!
[Re: Tadams]
#1140187
12/20/11 06:36 PM
12/20/11 06:36 PM
RapidRobert
Hi tom, yes the ammeter has continuity. trace the black wire downstream & see if you can find the open. do you have fire at the fuse box? Everything (almost) is hot so be careful what you bump/touch. What I do is take off a batt cable & put an inline fuse holder in series w a 20 amp fuse for protection (& a tin of 5 fuses)
[Re: Tadams]
#1140188
12/20/11 06:44 PM
12/20/11 06:44 PM
Andrewh
http://www.mymopar.com/index.php?pid=26probably have to go here to chase it down. if you have power on the black from the amp meter, then you should be good. pretty much all your power taps off that at a single splice after the amp meter. but the diagram shows a breaker attached to the amp meter too. no idea where that goes to. the fact you don't have ignition or headlights is weird. and it could still be the amp meter. you are reading voltage not amps. there may be 12 volts there, but maybe the amp meter won't pass enough amps to make anything work.
[Re: Tadams]
#1140190
12/21/11 10:37 AM
12/21/11 10:37 AM
RapidRobert
Tom I thought we had the major open fixed. Should I just come down there & take it off your hands so you can be done w it. I hate to have this be a Christmas distraction for you having family and all and I am certainly willing to go out of my way and help a fellow Moparter out. I hear it's beautiful country down there ![](/ubbthreads/images/graemlins/wink.gif) . What Andrewh said the black wire from the ammeter to the firewall bulkhead out to the alt it splits before it hits the bulkhead & T's to the fuse box the headlights and the ign sw so there's a splice in the harness right behind the dash instrument cluster. Might pull the dash again! (you could prob do it blindfolded w all the practice you've had) & unwrap/check that splice
[Re: Tadams]
#1140192
12/21/11 11:43 AM
12/21/11 11:43 AM
RapidRobert
I figured after solving the dead cyl you'd never let it go. Yes what Andrewh said if the ammeter has full continuity I'd unwrap that T esp if everything is dead but w more thought I just cant see the T loosing continuity to all 3 so yes start at the ammeter cause the red into it has fire correct?
[Re: Tadams]
#1140195
12/21/11 12:41 PM
12/21/11 12:41 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Ok, a few weeks ago I removed the gauge assemble from the dash of my 65 Barracuda to replace some light bulbs. When I put it back in I had no power to anything. After removing and installing it several times it started to work. Today I removed it to replace the voltage limiter and now I have no power again. The red wire has voltage and the black wire shows voltage so the amp gauge is good. The assemble is grounded to the dash by the 4 screws that hold it in place. There are only the black and red wires to the amp gauge and the plug that plugs into the gauge assemble and the plug to the ignition switch. Everything is wired and the plugs are in place. The unit is grounded so what else do I check? I have no power to start the car or headlights or power at all. Any ideas? thanks
I'm wondering if your voltage limiter is good... you replaced it then you dont have power ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Tadams]
#1140197
12/21/11 12:53 PM
12/21/11 12:53 PM
MR_P_BODY
This is a new solid state unit. Even if it was bad that shouldn't effect the starter should it. I think that would only effect the gauges. Thanks for the help and correct me if I'm wrong
You are correct... with the symptoms it acts like a ignition switch... is it plugged on good ... I dont recall if you said the head lights work or not ![](/ubbthreads/images/graemlins/wave.gif)
[Re: Tadams]
#1140201
12/21/11 04:30 PM
12/21/11 04:30 PM
RapidRobert
Using a non Mopar to make sure a Mopar makes it home yes that is very cold/disrespectful
