electrical help please #1140182
12/20/11 05:32 PM
12/20/11 05:32 PM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
Ok, a few weeks ago I removed the gauge assemble from the dash of my 65 Barracuda to replace some light bulbs. When I put it back in I had no power to anything. After removing and installing it several times it started to work. Today I removed it to replace the voltage limiter and now I have no power again. The red wire has voltage and the black wire shows voltage so the amp gauge is good. The assemble is grounded to the dash by the 4 screws that hold it in place.
There are only the black and red wires to the amp gauge and the plug that plugs into the gauge assemble and the plug to the ignition switch.
Everything is wired and the plugs are in place. The unit is grounded so what else do I check? I have no power to start the car or headlights or power at all.
Any ideas? thanks
Re: electrical help please [Re: Tadams] #1140183
12/20/11 05:48 PM
12/20/11 05:48 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Do you have power befor the dash, like in the bulk head connector, cigar lighter, interior lights?
Might want to make sure you are getting power into the cab then try to find out where it is or isn't going. Kinda sounds like the fuseable link. It's a heavy (red?) wire coming out of the bulk head connector into the engine compartment. It will have a yellow tag that says fuseable link if still stock. If this goes you will have no power. Might have shorted something putting the gauge cluster in and out a lot.
I have mechanical Aptitude.
I can screw up anything.
Re: electrical help please [Re: bboogieart] #1140184
12/20/11 06:14 PM
12/20/11 06:14 PM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
thanks for the advice. I have power to the red wire that hooks to the back of the gauges. Being I have it there could the fuseable link still be a problem.
Re: electrical help please [Re: Tadams] #1140185
12/20/11 06:17 PM
12/20/11 06:17 PM
Hampton, Ga.
70dart360 Offline
Green Meister
70dart360  Offline
Green Meister
Hampton, Ga.
Amp gauge may be whacking out, buypass it and try it again.
70 Dart Swinger 72 D-100 440 shortbed 76 Pinto, 68k 21mpg!
Re: electrical help please [Re: 70dart360] #1140186
12/20/11 06:23 PM
12/20/11 06:23 PM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
I have power to the red wire and the black wire shows power so that should mean the amp gauge is working, doesn't it. I'm not really sure.
Re: electrical help please [Re: Tadams] #1140187
12/20/11 06:36 PM
12/20/11 06:36 PM
Hi tom, yes the ammeter has continuity. trace the black wire downstream & see if you can find the open. do you have fire at the fuse box? Everything (almost) is hot so be careful what you bump/touch. What I do is take off a batt cable & put an inline fuse holder in series w a 20 amp fuse for protection (& a tin of 5 fuses)
Re: electrical help please [Re: Tadams] #1140188
12/20/11 06:44 PM
12/20/11 06:44 PM
Andrewh Offline
Andrewh  Offline
http://www.mymopar.com/index.php?pid=26
probably have to go here to chase it down.
if you have power on the black from the amp meter, then you should be good.
pretty much all your power taps off that at a single splice after the amp meter.
but the diagram shows a breaker attached to the amp meter too.
no idea where that goes to.
the fact you don't have ignition or headlights is weird.
and it could still be the amp meter. you are reading voltage not amps.
there may be 12 volts there, but maybe the amp meter won't pass enough amps to make anything work.
Re: electrical help please [Re: Andrewh] #1140189
12/21/11 10:12 AM
12/21/11 10:12 AM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
Thanks for all of the advice. I guess it will have to wait till after Christmas to check it out. Just to much to do.
Merry Christmas to all.
Re: electrical help please [Re: Tadams] #1140190
12/21/11 10:37 AM
12/21/11 10:37 AM
Tom I thought we had the major open fixed. Should I just come down there & take it off your hands so you can be done w it. I hate to have this be a Christmas distraction for you having family and all and I am certainly willing to go out of my way and help a fellow Moparter out. I hear it's beautiful country down there . What Andrewh said the black wire from the ammeter to the firewall bulkhead out to the alt it splits before it hits the bulkhead & T's to the fuse box the headlights and the ign sw so there's a splice in the harness right behind the dash instrument cluster. Might pull the dash again! (you could prob do it blindfolded w all the practice you've had) & unwrap/check that splice
Re: electrical help please [Re: RapidRobert] #1140191
12/21/11 11:37 AM
12/21/11 11:37 AM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
Hi Robert, I'll pass on you coming to take it off my hands. I did finish the leaf springs and replaced all of the shocks. I've been underneath removing rust and painting. I have the rust under control up to the where the floor pans will have to be patched or replaced. I really need to remove the entire dash and start cleaning the rust from that area. I was waiting till I had the windshield removed to start that but it may be a good time. There has to be a short in the circuit being this happened last time I had it out.
Come on down to North Carolina, it is a beautiful place to live. After being in 46 states while working, I have found beautiful places in every place I have been. You may have to look harder in some than others, but its still there. The nice part of where I live in the piedmont is I am 3 hours from the ocean and 2 hours from the mountains.
Hope you have a Merry Christmas. Now I have to go bake cookies and roll peanut butter balls. Thats what happens when your wife works and you stay at home. That means the car has to wait till after the weekend.
talk to you soon. have a great day.
Re: electrical help please [Re: Tadams] #1140192
12/21/11 11:43 AM
12/21/11 11:43 AM
I figured after solving the dead cyl you'd never let it go. Yes what Andrewh said if the ammeter has full continuity I'd unwrap that T esp if everything is dead but w more thought I just cant see the T loosing continuity to all 3 so yes start at the ammeter cause the red into it has fire correct?
Re: electrical help please [Re: RapidRobert] #1140193
12/21/11 11:53 AM
12/21/11 11:53 AM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
The red wire shows 12.5 volts and the black wire shows the same. so the problem comes after that point. Its strange that when this happens I have no lights or anything else. The ignition switch is dead, but I will find it. I think I have another wiring harness if I had to change that I could. Not one of those projects I wanted to do, but if it would solve this than maybe I should. There is no power at the fuse box, I think you had ask me earlier.
Re: electrical help please [Re: Tadams] #1140194
12/21/11 12:09 PM
12/21/11 12:09 PM
The red wire shows 12.5 volts and the black wire shows the same. Not one of those projects I wanted to do, but if it would solve this than maybe I should.
Actually a wire the thickness of a strand of hair will still show 12V potential but no significant flow can go thru that small of an opening but you'd think with 12v on the downstream of the ammeter that that is not the prob but I'm surprised all 3 component that are fired from the T are dead. None of them are showing any potential (~12V on the VOM)/are 100% dead
Re: electrical help please [Re: Tadams] #1140195
12/21/11 12:41 PM
12/21/11 12:41 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Any ideas? thanks
I'm wondering if your voltage limiter is good...
you replaced it then you dont have power
Re: electrical help please [Re: MR_P_BODY] #1140196
12/21/11 12:49 PM
12/21/11 12:49 PM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
This is a new solid state unit. Even if it was bad that shouldn't effect the starter should it. I think that would only effect the gauges.
Thanks for the help and correct me if I'm wrong
Re: electrical help please [Re: Tadams] #1140197
12/21/11 12:53 PM
12/21/11 12:53 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You are correct... with the symptoms it acts like
a ignition switch... is it plugged on good ... I
dont recall if you said the head lights work or not
Re: electrical help please [Re: MR_P_BODY] #1140198
12/21/11 12:58 PM
12/21/11 12:58 PM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
I don't have anything, no headlamps, brakelights, interior lights. I think my neighbor with the camaro put a jinks on it. The ignition switch is pluged in well, I checked that last night.
Re: electrical help please [Re: Tadams] #1140199
12/21/11 01:10 PM
12/21/11 01:10 PM
The T is just a soldered connection wrapped in the black electrical tape on the main loom just behind the dash. I could perform an exorcism (which has to be done in person) then take it for a cross country jaunt (west) just to confirm it's healed. I'm pricing a bus ticket as we speak. Your baking cookies ,no wonder you have a happy family, save me some EDIT make up a long jumper wire with alligator clips on each end (you'll use it many times in the future) & jump from the batt positive post to the downstream lug on the ammeter and check the batt large negative cable also if any doubt about it's continuity. lets get the ammeter out of the way
Re: electrical help please [Re: RapidRobert] #1140200
12/21/11 01:33 PM
12/21/11 01:33 PM
North Carolina
Tadams Offline OP
Tadams  Offline OP
North Carolina
Peanut butter balls and cookies. Thats my orders for today from the boss. I even left a list for Santa for a few small auto parts. Santa quickly said no. Santa is not real fond of my gold fish. I informed her when I was finished and went to my first car show she wasn't allowed to ride with me, She said she didn't want to, she would follow me in her Jaguar to make sure I made it home. That's cold, don't you think?
Re: electrical help please [Re: Tadams] #1140201
12/21/11 04:30 PM
12/21/11 04:30 PM
Using a non Mopar to make sure a Mopar makes it home yes that is very cold/disrespectful
