'69 Swinger axle package code? #1139292
12/19/11 12:42 PM
12/19/11 12:42 PM
NY
70440+6bbl Offline OP
NY
I just bought a very original '69 Swinger 340 4-spd that came equipped with the 3.91 sure grip. The fender tag is not coded A31, was this just an oversight when the tag was stamped or just the way it was at Hamtramck in '69? The only guess I have is since there was no cooling system upgrade on the A-body, it wasn't considered an axle package, maybe?
The two broadcast sheets and the original order form and invoice state it was ordered with the 3.91 gear set. Sheet code D57/D91.
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: '69 Swinger axle package code? [Re: 70440+6bbl] #1139293
12/19/11 01:43 PM
12/19/11 01:43 PM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I'll have to look at the tag on my dart tonight it's a 3.91 car.
Re: '69 Swinger axle package code? [Re: JohnRR] #1139294
12/19/11 02:11 PM
12/19/11 02:11 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Correct, the '69 a-bodies didn't have an axle "package" - so the b'cast or window sticker is needed to determine the original axle ratio.
I believe - if you ordered the "sure-grip" for ~ $42, the 3.55s or 3.91s were "no-charge".
Re: '69 Swinger axle package code? [Re: 6bblgt] #1139295
12/19/11 02:41 PM
12/19/11 02:41 PM
NY
NY
Dan, that is what I figured. I remember BOS had an identically equipped car to mine and IIRC, it had A31 on the tag (not the SPD;-)).
Edit: I found the Dart on their site in the sold car section and the tag is probably a repop:o I would post a pic, however the right click is disabled.
Re: '69 Swinger axle package code? [Re: 6bblgt] #1139296
12/19/11 03:23 PM
12/19/11 03:23 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Correct.
3.55 and 3.91 were optional and NC with a Sure Grip. 3.91's were not available if the vehicle had AC.
Re: '69 Swinger axle package code? [Re: 70440+6bbl] #1139297
12/19/11 03:32 PM
12/19/11 03:32 PM
JohnRR Offline
JohnRR  Offline
Post a link to the auction , repop tag is easy to spot .
Re: '69 Swinger axle package code? [Re: JohnRR] #1139298
12/19/11 06:46 PM
12/19/11 06:46 PM
NY
NY
Re: '69 Swinger axle package code? [Re: 70440+6bbl] #1139299
12/19/11 07:20 PM
12/19/11 07:20 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
nice tag lots of ERRORS makes one wonder what is correct about the car?
Re: '69 Swinger axle package code? [Re: 70440+6bbl] #1139300
12/19/11 07:35 PM
12/19/11 07:35 PM
JohnRR Offline
JohnRR  Offline
Here you go John
http://www.rkmotorscharlotte.com/inventory/1969-Dodge-Dart-Swinger/131432
I am not going to say anything on that subject because I don't feel like dealing with Joe Carrol's pitbulls ...
Re: '69 Swinger axle package code? [Re: 6bblgt] #1139301
12/19/11 07:36 PM
12/19/11 07:36 PM
JohnRR Offline
JohnRR  Offline
Re: '69 Swinger axle package code? [Re: JohnRR] #1139302
12/19/11 08:25 PM
12/19/11 08:25 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Said car was sold. Too bad for someone.
Getting old just means you were smarter than some and luckier than others.
Re: '69 Swinger axle package code? [Re: dannysbee] #1139303
12/19/11 09:08 PM
12/19/11 09:08 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Wow, not even CLOSE to what a 69 Dart tag looks like! In my 33 years of checking those tags I have never seen A31 A46 J54 and M85 on ANY tag!
A quick edit: I have several tags with A42 on them, which was the Spring Special and it included the bumper guards. I have quite a few tags and none of them have the M85, though I believe some probably did.
JB Rhinehart, Realist
A-Body's RULE!
Re: '69 Swinger axle package code? [Re: Rhinodart] #1139304
12/19/11 10:52 PM
12/19/11 10:52 PM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
"My car didn't come with a tag. Where can I get a new one? I'll never try and fool anyone with a fake tag. I'll be honest about it. Everyone will know it's remade."
Seeking:
1969 St. Louis plant VINs, SPD, and VONs.
Over 2,000 thanks to you!
Re: '69 Swinger axle package code? [Re: 69CoronetRT] #1139305
12/19/11 11:14 PM
12/19/11 11:14 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
It has been on the car since April 18, 2007 at least. ( I have another image of it saved with that date)
Re: '69 Swinger axle package code? [Re: Rhinodart] #1139306
12/20/11 12:12 AM
12/20/11 12:12 AM
NY
NY
Here is the original tag to my 340 4-spd 3.91 Swinger. It does have A46 on it Jim.
Re: '69 Swinger axle package code? [Re: 70440+6bbl] #1139307
12/20/11 12:26 AM
12/20/11 12:26 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Cool! First time I have seen this, and I have looked at hundreds of 69 Dart tags. Most of the cars built late have different stuff on the tags than I have seen on earlier tags, this might be one of them. I have actually seen a 69 Swinger with factory buckets, fender turn signals, rocker mouldings, and a few other options you usually see on GTS's. They were on the fender tag, I think they were trying to get rid of inventory by then.
The A46 package consisted of:
upper door frame mouldings
drip rail mouldings
grille surround mouldings
wheel lip mouldings
deck lid lower mouldings
What mouldings are on your car? Since it has M21 it must have 2 sets of drip rail mouldings on top of each other?
A-Body's RULE!
Re: '69 Swinger axle package code? [Re: Rhinodart] #1139308
12/20/11 12:57 AM
12/20/11 12:57 AM
NY
NY
The car is disassembled for the most part, so I'll have to see what is there for certain. It does have the driprail trim and the holes in the wheelwells for the moldings. Doesn't appear to have ever had the lower decklid molding though, would there be holes in the lower lip?
Here is the invoice from the original selling dealership, which was Griffin Motors in Meadville, PA. The original owner traded in a '66 Mercury Cyclone in on the Swinger and received a $1,164.31 trade in allowance on the grand total of $3,264.35
Re: '69 Swinger axle package code? [Re: 70440+6bbl] #1139309
12/20/11 01:38 AM
12/20/11 01:38 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
There would be no lower moulding on a Dart. I am sure this package code would be used on other 69 body's and whatever was available for those body's would be included with the A46 code. I only know and care about Darts, so I wouldn't know what other cars may have the A46 code. It is another reason why it seems odd that the A46 AND the M21 would be on the same fender tag.
A-Body's RULE!
Re: '69 Swinger axle package code? [Re: 70440+6bbl] #1139310
12/20/11 02:25 AM
12/20/11 02:25 AM
JohnRR Offline
JohnRR  Offline
I just went and looked at the tag on my dart , no A31 on it , Plus it wasn't looking how I expected , but the engine compartment had been repainted once .
There is no A31 on my original broadcast sheet , just D57 and D91
Re: '69 Swinger axle package code? [Re: Rhinodart] #1139311
12/20/11 02:36 AM
12/20/11 02:36 AM
Harlan, Iowa
69CoronetRT Offline
69CoronetRT  Offline
Harlan, Iowa
drip rail mouldings
wheel lip mouldings
Were there new moldings added to the LM A46 package later in the year?
Wasn't A46 the only way to get M21 on a LM?
Seeking:
