Are 1966 Hemi blocks stamped with VIN's? #1138579
12/18/11 12:20 PM
12/18/11 12:20 PM
North of Detroit
HemiDart68 Offline OP
North of Detroit
Acquired a hemi block with 1966 casting date. There is no vin numbers stamped anywhere on the block by the oil pan rail. On the pad by the front of the intake is stamped "WT" I was told this stands for "water test" which is found on warrenty blocks or most hemi blocks. No other marking on the block at all. I am curious if i have a warrenty block or if chrysler was not stamping on VIN's on 66 blocks. I know they did not do it in 64 or 65 hemi blocks. Not sure about 66.
thank you
matt
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: HemiDart68] #1138580
12/18/11 12:57 PM
12/18/11 12:57 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
66 model year engines didn't have VIN#s but 66 blocks did get used in 1968 and those would have, the number would be stamped on the upper rear bell housing mating flange surface right into the bare cast iron adjacent to the oil sender hole.
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: ScottSmith_Harms] #1138581
12/18/11 04:03 PM
12/18/11 04:03 PM
North of Detroit
North of Detroit
excellent info. Thanks very much.
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: ScottSmith_Harms] #1138582
12/18/11 04:45 PM
12/18/11 04:45 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Also look for stampings in this area, it's usually going to have assembly info.
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: HemiDart68] #1138583
12/18/11 05:19 PM
12/18/11 05:19 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
The WT for water test does not prove something is a warranty block nor is it just a hemi thing. I have a69 440 block here that was installed in a production vehicle and has the W T stamp.
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: ScottSmith_Harms] #1138584
12/18/11 05:36 PM
12/18/11 05:36 PM
Warrenton, VA
RoadRunnerJD Offline
Warrenton, VA
I don't think it was common for the month day and year to be stamped on the bottom ear? I had a 65 and 67 Hemi block, both with an AH and a CH 426 respectively, year letter code on the top pad but I can't remember any assembly dates. I also had a 70 block with no year letter code or assembly date and only a WT but they all had the WT. I do not recall any having the day, month and year on the bottom?
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: RoadRunnerJD] #1138585
12/18/11 05:47 PM
12/18/11 05:47 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
There were different stampings on different years and for different purposes, this was the case in most of the stamping locations.
For 1966/67 production model year the top pads would have typically had something like this:
1966
BH426 WT
11 16 4
1967
CH426 WT
11 16 4
B=1966
C=1967
H=Hemi
WT= Water Tested Block
11 16 4 (random numbers I chose) is the assembly date and sequence number= November 16th, 4th engine
In 1968 they quit using the top pad alphabetical year and CID designation (example, there were no "DH426" stamped upper pads on Hemi engines, however it was continued that way for wedge engines.
The example of a pan rail I posted above was just to point out a location to look for further stampings, that particular example is typical for a warranty or service block, production engines typically carried a lot more info pertaining to the engine plant, 10,000 assembly date code, and assembly sequence info.
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: ScottSmith_Harms] #1138586
12/18/11 07:42 PM
12/18/11 07:42 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Odd as it may sound, I have a '66-cast Hemi block with a W (not WT) on the top pad, and what might be a very faint & partial (like 3 #s) VIN stamp @ the BH flange. Govier said it was a warranty block, but there's no sign of a warranty tag or rivet.
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: ScottSmith_Harms] #1138587
12/18/11 08:27 PM
12/18/11 08:27 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Stamped on mine and Rugtruckers 10th birthday!
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: ScottSmith_Harms] #1138588
12/18/11 08:29 PM
12/18/11 08:29 PM
Warrenton, VA
Warrenton, VA
1966
BH426 WT
11 16 4
1967
CH426 WT
11 16 4
B=1966
C=1967
H=Hemi
That's a good explaination. I didn't realize they discontinued the letter for the year after 67. I wasn't into the numbers back when I had Hemi's.
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: topside] #1138589
12/19/11 11:14 AM
12/19/11 11:14 AM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
I hate the term warranty used for a block that could have been bought by any Tom , Dick or Harry that walked up to the parts counter and bought one ...
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: JohnRR] #1138590
12/19/11 11:20 AM
12/19/11 11:20 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
IMO there are two (basic) catagories:
Warranty/Service/OTC/Other Replacement:
Basically any complete or incomplete engine assembly or bare block that was sold by Chrysler that was not originally installed in a car. Most of these had stamped markings and or rivoted on tags which helped decern one from the other in terms of which original form it when sold in (bare block, short block, complete engine, Marine Engine, etc.).
Production Line:
An engine that was originally installed into a production line car
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: ScottSmith_Harms] #1138591
12/19/11 02:29 PM
12/19/11 02:29 PM
North of Detroit
North of Detroit
Mr. Harm's
The block i have has a 66 casting date on the drivers side. Also has stampings on the pan rail exactly like this. The stampings on the pan rail are a few months after the casting date also 1966 so i am assuming this is the assembly date of the motor.
On the engine Pad on top by the intake I only have the stamping of "WT" noting else. No BH-426 or any other anything of the sort. Would this imply that it wasn't a car engine and over the counter block? Or is there not really enough info to say for certain?
On an unrelated question what kind of block is the marine block you took a picture of? are you aware of chrysler having any 426 marine hemi's?
thanks much
matt
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: HemiDart68] #1138592
12/19/11 02:34 PM
12/19/11 02:34 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
thanks much
matt
Matt ,I'm sure Scott will correct me if I'm wrong , I believe Hemis were built by the Marine division, at least the whale hemi's were .
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: HemiDart68] #1138593
12/19/11 02:42 PM
12/19/11 02:42 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Your block was likely a replacement engine or short block assembly. At the very least it was an assembled short block (block.crank, rods & pistons) which is why it has an assembly date.
If you find a brass rivot in the block somewhere (rivots similar to the rivots that hold that Marine engine tag on) that's where a tag would have been which would have further info on it identifying what the assembly was (or was not). Most tags were affixed to the side of the block near a frost plug hole, some where on the front face of the blocks below the deck sruface. At any rate, if you don't find a tag you won't likely be able to tell what it originally was. See example of a 68 Hemi block with a rivot below.
The name "Marine" adds confusion to the intended application of the engine above. To explain you need to understand that many "Special" engines (regardless of the end application) were ASSEMBLED by Chryslers Marine Division.
The engine above was an original 1964 version of a Chrysler Cross Ram Race Hemi, it was purchased as a complete crate engine assembly from Chrysler by Kieth Black and installed into a customers car, apparntly after the customers original 66 Hemi Coronets engine blew.
These engines were available over the counter to anyone with the money to buy one and they went into all kinds of cars, boats, and other drag machines of the day.
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: ScottSmith_Harms] #1138594
12/19/11 04:20 PM
12/19/11 04:20 PM
Strathroy, Ontario
BS27R1B Offline
BS27R1B  Offline
Strathroy, Ontario
Is that a date on the tag for the 64 engine? It is laid out like a date 8/13/05.
does these read May 13 1968? As I doubt it was Aug 13 2005.
'.. it was long ago and it was far away, and it was so much better than it is today..'
Jim Steinman
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: BS27R1B] #1138595
12/19/11 06:24 PM
12/19/11 06:24 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes it's a date, August 13, 1965
It's a replacement engine (or no intended purpose but as a Hemi to sell to racers, etc.) built in August of 1965 for sale over the counter and has cast iron K heads. My guess is that they were using up leftover iron K-heads to build them as opposed to the aluminum headed 1965 A990 versions.
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: HemiDart68] #1138596
02/12/15 03:07 PM
02/12/15 03:07 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Ressurecting an old thread...
an acquaintance of mine asked me about a Hemi block he is looking at and what its stampings may mean. On the top pad it has CM-426-RB. I would have guessed this to be a '67 casting because of the C, but the casting date on the side of the block says 1-17-68. It does have the 2468330 casting number on it so does that means it was a race version or a street version or does it matter?
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: TC@HP2] #1138597
02/12/15 03:09 PM
02/12/15 03:09 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
That is not a typical stamping, do you have a picture it?
Re: Are 1966 Hemi blocks stamped with VIN's? [Re: ScottSmith_Harms] #1138598
02/12/15 06:18 PM
02/12/15 06:18 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Not currently. I'll see if he can produce one.
