Re: cast 400 or 383 steel crank
[Re: westdart68]
#1138199
12/17/11 07:34 PM
12/17/11 07:34 PM
Posts: 4,384 Madison Wi
NTOLERANCE
Madison Wi
400 pistons are heavier than 383 pistons.
It will vibrate...
[Re: NTOLERANCE]
#1138200
12/17/11 08:53 PM
12/17/11 08:53 PM
Posts: 25,842 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Most sources show the forged 400 and the forged 383 cranks as a straight interchange.
[Re: westdart68]
#1138202
12/18/11 01:41 AM
12/18/11 01:41 AM
RapidRobert
With a cheap Harbor Freight digital scale weigh one of the 383 rod/piston/ring/bearing assys' and one of the 400 ring/piston/ring/bearing assys' & post the difference. For the bobweight amt on each journal (4) the reciprocating weight of 1 assy's is used as is plus the rotating weight of 1 assy is doubled then add both sums up but in effect each assy should be the same (or close), for a start post what you get just as if 2 sacks of money contain the same # of pennies and the same # of nickels they will weigh the same. Unless someone has a definitive ans I'd wanna know now (one way or the other) rather than later (& maybe have to start over)
[Re: westdart68]
#1138204
12/18/11 01:02 PM
12/18/11 01:02 PM
Posts: 75,042 U.S.S.A.
JohnRR
U.S.S.A.
Have the rotating assembly balanced, trying to find the correct external balance flywheel USED, is going to be next to impossible. the balance job from the factory wasn't that good to begin with , do yourself a favor and have it balanced using the forged crank.
Next dumb observation ... rotating assembly KIT ??? be careful , 400's were low compression from the factory there are very few pistons available that aren't .100 or more in the hole, any would be from companies like ross, diamond, etc ...
Sounds like you are trying to do this on the cheap, you may be disappointed with the outcome.
[Re: JohnRR]
#1138205
12/18/11 05:52 PM
12/18/11 05:52 PM
John_Kunkel
Rio Linda, CA
On the subject of 383 versus 400 internal balance, keep in mind that forged crank 383's all had higher compression height than any 400 so the extra weight that comes from the larger diameter of the 400 piston is offset by the taller compression height of the 383; since the rods and pins are the same, the bobweight would probably be near the same for both (within factory tolerances).
[Re: JohnRR]
#1138207
12/18/11 09:07 PM
12/18/11 09:07 PM
John_Kunkel
Rio Linda, CA
My argument is to why the forged 383 and 400 cranks are an interchange in original form.
[Re: John_Kunkel]
#1138208
12/19/11 11:51 AM
12/19/11 11:51 AM
JohnRR
U.S.S.A.
I'm not trying to argue that point , just pointing out something so the OP doesn't think he can stick a lightweight aftermarket piston or lighter than stock KB piston on the 383 crank and not have to rebalance it.
