some vacuum advance real world testing
#11375
05/13/04 10:50 AM
05/13/04 10:50 AM
Just though I'd pass this info along; it may or may not be applicable to your setup. It's just one more data point.
I posted last week that I was having some slight pinging when mashing the accelerator from cruise (2200 RPM, 4th gear). I was wondering if the vacuum advance had anything to do with the pinging.
Well, I disconnected the vacuum advance and went for a test drive, and the result was no pinging.
My conclusion is that the vacuum advance does not act instantaneously...even if the vacuum signal drops to 0 when the throttle is wide open, it appears as though it takes a second or two for the vacuum advance to return to 0.
FYI. If anybody has other thoughts, or similar experiences, please let me know.
Re: some vacuum advance real world testing
#11376
05/13/04 12:40 PM
05/13/04 12:40 PM
#11377
05/13/04 01:47 PM
05/13/04 01:47 PM
As I've just spent the better part of a month playing with advance, distributors and ignition systems... here's what I know about a stock vacuum advance:
Though rated at 15-20"Hg. The diaphram in an advance unit I tested began to move at only 7"Hg and was fully engaged at 12"Hg as tested with a reliable, leak tested Snap-On vacuum pump. What the vacuum is released from the unit (during testing, of course) the spring SNAPs the rod back to the original static position. There is no bleeding or drifting. My unit as tested had an exact and immediate response to negative pressure, as applied.
#11378
05/13/04 02:42 PM
05/13/04 02:42 PM
Ok, let's assume that what you state above is true.
Then, given my test, I would have to assume that manifold vacuum did not drop to 0 immediately after mashing the pedal, but instead took some small amount of time. That's a valid assumption, isn't it?
Is this possible/probable? If so, would it indicate a problem with the opening of my secondaries (they are vacuum acuated)?
Do all 4 barrels need to be wide open for vacuum to drop to 0?
[Re: Clair]
#11380
05/13/04 03:13 PM
05/13/04 03:13 PM
Nothing happens instantly
3000 RPM / 60 seconds= 50 RPS Crank takes 2 revolutions to fire piston
25 fires per second * 8 cylinder = 200 cylinder fires per second
Let’s say it takes 250 ms (1/4) second for the advance to return That’s still 50 cylinder fires while it is coming off of the advance. Ping Ping
Thanks Clair.
This brings me back to the point I was making last week in a posting: given this situation, is it impossible to eliminate all pinging, under all circumstances, with a manual transmission?
I mean, we've got 50 degrees of advance (even if it's for less than a second), and we place a major load on the engine by stomping on the accelerator. Why shouldn't some pinging be expected?
#11382
05/13/04 03:55 PM
05/13/04 03:55 PM
Posts: 575 El Cajon, CA
dart70la
super gas
super gas
El Cajon, CA
It might be expected, but it can not be tolerated.
That is probably why a lot of rodders run without the vacuum advance.
R-E-S-P-E-C-T, Hard to earn, easy to lose.
[Re: dart70la]
#11383
05/13/04 04:00 PM
05/13/04 04:00 PM
I agree. I'm just wondering if I still have a tuning issue, or if it's something that can't be avoided.
That's what I'm gonna do next, and see how it affects mileage. Are there any other effects I should expect by not using vacuum advance at all?
#11384
05/13/04 04:22 PM
05/13/04 04:22 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
I will put in my 2 cents worth here. The amount that you will save if anything will be like driving to the next town to save a penny a gallon on gas. Especially on performance orianted engines.
Back in the early years of EPA envolvemnt in the industry we had many complaints of no power, poor milage, etc.
We recalibrated the carburator and the distributor, timed the total advance and put a ball bearing in the vacume hose so that it looked functional. Most of the people were pleased with the cars after the 'tune up'. Some you could never please. There are those that no matter what you can't please like the ones that want to pull a trailer 70 MPH and still get 20 MPG.
You don't see many HP distributors with a vac adv.
Clean it, if it's Dirty. Oil it, if it Squeaks.
But: Don't fix it, if it Works!
[Re: MoparforLife]
#11385
05/13/04 04:34 PM
05/13/04 04:34 PM
If you are getting a one or two hit rattle just as you hit the throttle, and then it goes away, you probably have a combination problem that involves the vacuum advance and the accellerator pump. Usually, if you disconnect the vacuum advance and it goes away, you can make it better by making sure everything is moving well and the vacuum line is big enough to drop the cannister quickly. Often though, the real problem is that the engine runs momentarily lean until the main metering system catches up. Not lean enough to cause a sag, but lean enough to detonate if you are close to it anyway, with compression or fuel quality. A touch more pump shot, or bringing the shot on a touch earlier in the throttle motion may take the detonation out even with the vacuum advance in place.
The other thing that I have seen is that engines running on the modern fuels, with hot ignitions, and particularly if they have high quench, seem to require a bit less advance, especially under light load. The days of having 50 degrees total at cruise appear to be gone, and low 40's seem to work a lot better from an economy, and tip in performance standpoint. This is based on having a total mechanical of the old standard 35 degrees (which may also need to be backed off by a couple).
I like to run a vacuum advance for the economy and the fact that at cruise it will keep the insides of the engine cleaner with less carbon buildup.
[Re: MoparforLife]
#11386
05/13/04 04:36 PM
05/13/04 04:36 PM
Posts: 8,215 Cornfield. IN
Clair
Pot Stirrer #4
Pot Stirrer #4
Cornfield. IN
Some people put 5000 Miles + a year on.
Not race motors just a nice street motor.
I will take the extra 2 -3 mpg my vacuum advance is giving me.
Good points Booster.
Also engine temp/incoming air temp
Not easily controlled but you do notice the hotter the engine temp the easer it pings
[Re: Clair]
#11387
05/13/04 09:18 PM
05/13/04 09:18 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
i know Crane used to sell an adjustable vacuum canister for the OE Mopar distributors. ive used a few in the past and had pretty good luck with them. i dont know if they are still avalable or not.
i agree with Booster in that you might want to limit the amount of vacuum advance into the low-40's.
FWIW, my computer controlled 93 Dakota doesnt seem to ever go over 44deg of timing.
