How would you go about fixing this? #1137294
12/16/11 08:07 PM
12/16/11 08:07 PM
Northeast, Alpine, NY
9
9 Sec Phill Offline OP
On a road near you
On a road near you
9
Other then cleaning the waterpump and treating it with some type of acid or cleaner how do you keep from getting this corrosion other then priming before paint? Any help would be great. Thanks...
Re: How would you go about fixing this? [Re: 9 Sec Phill] #1137295
12/16/11 08:56 PM
12/16/11 08:56 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Use distilled water.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: How would you go about fixing this? [Re: moparmarks] #1137296
12/17/11 12:07 AM
12/17/11 12:07 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i'd also consider a sacrificial anode for the radiator. some sealant on the bolts too.
Re: How would you go about fixing this? [Re: 9 Sec Phill] #1137297
12/17/11 12:33 AM
12/17/11 12:33 AM
N
NITROUSN Online content
NITROUSN  Online Content
N
I doubt that's a new corrosion problem. Looks like it was put together cracked and then the moss started growing.
Re: How would you go about fixing this? [Re: 9 Sec Phill] #1137298
12/17/11 12:40 AM
12/17/11 12:40 AM
Permatex #3 aviation gasket sealer on the hoses/nipples and Permatex #2 (stays pliable) in the toothpaste like tube on the bolt threads that hit coolant
