Page 2 of 8 1 2 3 4 5 6 7 8
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135424
12/16/11 07:43 PM
12/16/11 07:43 PM
scratchnfotraction Offline
mine is a daily driver with a stock 440 with 75.000 miles,built from a rust free Kansas truck with 58.000 miles on it,best condition seat i have ever saw till seeing yours
yes they have plenty or after market rims and some of the other stock rims fit.
my stepside has the 5 on 5.5 wagon spoke rims with the 85 center caps and trim rings.
just check the axle register on the newer stock rims i dont care for any of the stock old or new myself
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: Kevin I] #1135425
12/16/11 07:43 PM
12/16/11 07:43 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I wish I could find something like that to drive so I can keep my trucks out of the weather. Is it pretty loaded up as far as options go?
AC !
And the upgraded seat and door panels, am/fm
They were still awful basic trucks in 1989
If anyone wants it more than me, I'll send'r down the road too
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135426
12/16/11 07:45 PM
12/16/11 07:45 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Windows roll !
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135427
12/16/11 07:46 PM
12/16/11 07:46 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
It is here at the Church of Chrysler unless ..
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: ram87] #1135428
12/16/11 07:47 PM
12/16/11 07:47 PM
Abilene,Texas
ram87 Offline
ram87  Offline
Abilene,Texas
Or maybe this one shows a little better. Have to remember the rear tires are 33X21.5X15 so they are kind of tall.
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135429
12/16/11 07:48 PM
12/16/11 07:48 PM
does it have the steering box frame brace?
swaybar?
i bet it wont have the dodge truck driverside lean to it with that low milage and nice shape.
the back seems a tad high,but ihave seen one stock in a long time.
is it a TBI roller cam 318?
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: scratchnfotraction] #1135430
12/16/11 07:51 PM
12/16/11 07:51 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
swaybar?
I'll have to look to see if it has brace, just got here
Yeah it has the stink bug stance, no lean to drivers side
Yep, thats the 1st year for it
Original brochure is laying in truck
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135431
12/16/11 07:57 PM
12/16/11 07:57 PM
Abilene,Texas
ram87 Offline
ram87  Offline
Abilene,Texas
My has a Chisolm front end. Rear is a Dana 60, two leafs per side, narrowed frame rails and rear end.
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: ram87] #1135432
12/16/11 08:34 PM
12/16/11 08:34 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
nice truck
there are a few nice 5.5 wheels out there. a lot more 4.5s.
the 81/84 rotors are a bolt on. the rears can be redrilled along with the drum.. a 4.5 drum will work but the center hole needs to be enlarged to fit the axle register..
I am truckless..
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: 340SHORTY] #1135433
12/16/11 08:41 PM
12/16/11 08:41 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Can you buy new rotors at Napa with the 4 1/2 pattern ?
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135434
12/16/11 09:32 PM
12/16/11 09:32 PM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
What custom wheel choices are there , or do they all look like 4x4 wheels ?
Can I use wheels off a late model base Dodge van, the ones that are kinda like rally wheels ?
I think I know where I can get a set of those , IIRC they are 16's .. right ?
Nice truck! The wheels I think you're speaking of are the aluminum ones with the holes, right? If so, they are like the ones that were on our 92 Dodge perversion van. They are 15" wheels. Good luck with the truck.
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: JDMopar] #1135435
12/16/11 09:39 PM
12/16/11 09:39 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
No, the ones I was thinking of look a lot alike the wheels you would see on a 76 Chrysler New Yorker
Its steel wheel , with a trim ring and a chrome center cap, they are steel, painted silver
My friend has these on his, they look pretty good too
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135436
12/16/11 09:47 PM
12/16/11 09:47 PM
east side of Ohio
basketcase Offline
basketcase  Offline
east side of Ohio
I have searched for a Squarebody Dodge 81-93 Shortbox for years , it had to be nice..
This one is really, really original and CLEAN !
beautlful truck my elghty elght has a/c and crulse w/ V6. nlce body except for the bed above the wheels. got panels from Scratch to flx that.
1981 Dodge D150 360 auto
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135437
12/16/11 09:50 PM
12/16/11 09:50 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The rotors will fit from 84-down. You can use the 4.5 axles from 84-down if you have a 81/4 rear the carrier is the same for those from 1966-1996 [as per Auburn Differential] If you have a 91/4 84' model axles are the key to the swap [according to the Chrysler parts catalog] A true 3/4 ton [1/2"lugs] does not have a pocketed control arm Trucks with 9/16"-5/8" lugs have a pocketed control arm. All vans 78-98 with 1/2" studs have pockets & correct size balljoints. Dakota Drop spindles & a balljoint reamer for the steering arm work. You ream from the opposite side so the tierods don't have to be turned over. A 3" drop spring for a 94up Ram will get you 2". The rear is up to you
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135438
12/16/11 09:57 PM
12/16/11 09:57 PM
JDMopar Offline
JDMopar  Offline
Ok...that's all I got in truck/van wheel knowledge! Right off hand, I'd say listen to Scratchinfotraction and forget the rest of us...lol. Well, maybe Mopar Jamie too.
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135439
12/16/11 10:04 PM
12/16/11 10:04 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I'm sure somewhere, there is a nicer one but, this one is about perfect , if you consider its 20+ years old
It has a couple small little dings but nothing bad anywhere
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! *DELETED* [Re: JDMopar] #1135440
12/16/11 10:16 PM
12/16/11 10:16 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Post deleted by BulletBob
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135441
12/16/11 10:18 PM
12/16/11 10:18 PM
yes ask for a 83-84 d-150 or 76 newyorker front rotors
they swap right on with the same wheel bearing
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: scratchnfotraction] #1135442
12/16/11 10:24 PM
12/16/11 10:24 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
If you have the 9 1/4 rear,,, you CANNOT use the 84 and prior axle shafts in a 85 and later axle houseing..
I am truckless..
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: 340SHORTY] #1135443
12/16/11 10:43 PM
12/16/11 10:43 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
According to Auburn Differential the end of the axle changed after 1983. I had them on the phone this week after I got your PM about your hydra loc. Now I haven't dug out my Factory parts catalog yet but if what the guy at Auburn Differential is right then that means that an 84 axle will work. {I just double checked their catalog & the installation instructions too} According to them the change was after 1983.The 8.25 will interchange. The end of the axle never changed. Bigdad's truck having a 318 will most likely have a 8.25 Bob
