Page 1 of 8 1 2 3 4 5 6 7 8
My new ( to me ) 1989 Dodge D-100 shortbox ! #1135404
12/16/11 06:42 PM
12/16/11 06:42 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I have searched for a Squarebody Dodge 81-93 Shortbox for years , it had to be nice..
This one is really, really original and CLEAN !
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135405
12/16/11 06:45 PM
12/16/11 06:45 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
If someone can ,,
Photoshop it dropped down about 2/4 and all dark blue
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135406
12/16/11 06:47 PM
12/16/11 06:47 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Need to remove all the autozone junk he added on , like toolbox, floor mats , bug guard
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135407
12/16/11 06:50 PM
12/16/11 06:50 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I will be asking a lot of questions that , I'm sure have been asked before .
Like what trim parts can you still get, can I swap it to a 4 1/2 bolt pattern without a big hassle and ..
It is a 318 , auto has air, and it works !
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135408
12/16/11 06:52 PM
12/16/11 06:52 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
This picture came out lousy ?
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135409
12/16/11 06:55 PM
12/16/11 06:55 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
125,000 original miles , sat in a garge for years so the story goes , it does look like it
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135410
12/16/11 07:02 PM
12/16/11 07:02 PM
New York
jagrunt551 Offline
jagrunt551  Offline
New York
Very good looking truck!!!
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135411
12/16/11 07:02 PM
12/16/11 07:02 PM
Maine
jerseybud Offline
jerseybud  Offline
Maine
Looks good- saw a rusty one with same paint get crushed yesterday. Frame broke in half....
No easy way to go to 4.5 bolt pattern. Rear could be re-drilled (hacky) but fronts would need new hubs- are spindles compatible between the 2?
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135412
12/16/11 07:04 PM
12/16/11 07:04 PM
scratchnfotraction Offline
84 truck rotor or 76 new yorker rotors get the front
will take an earlier rear axle,cant just swap them/change in c-clip
c-body 8 3/4 is same as truck 8 1/4 or 9 1/4
the shackle flip with front hanger is good for 4-5 inches in the rear with axle floped on top of springs. can flip the front hanger also for another little bit.
A-body 8 3/4 bolts in and tucks 12" rims with 29x15x15 M/Ts in the fenders like mine.(did both my stepside and wide box)
3/4 or 1 ton pocketed lower control arms with stock 1/2 ton spring or shorter for the front,get offset upper bushing to help alinement.
very nice truck
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: jerseybud] #1135413
12/16/11 07:06 PM
12/16/11 07:06 PM
Round Rock,Tx
N
Nirvana Offline
Nirvana  Offline
N
Round Rock,Tx
Saweet!!! That thing is awesome,im hoping to get my 87 looking that nice.I would buy the floor mats from you when you get rid of them.
Jared
87 D100 225 4 speed.
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: scratchnfotraction] #1135414
12/16/11 07:07 PM
12/16/11 07:07 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
What custom wheel choices are there , or do they all look like 4x4 wheels ?
Can I use wheels off a late model base Dodge van, the ones that are kinda like rally wheels ?
I think I know where I can get a set of those , IIRC they are 16's .. right ?
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135415
12/16/11 07:09 PM
12/16/11 07:09 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
It really is a time capsule, it shows hardly any wear and tear ..anywhere
I'm not a fan of two-tone
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: Nirvana] #1135416
12/16/11 07:10 PM
12/16/11 07:10 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Jared
You can have them
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135417
12/16/11 07:11 PM
12/16/11 07:11 PM
I run weld rims with 5 on 4.5 in my 88 440 truck
some of the bigger newer rims do swap over IIRC
the stock canyon sport rims are alum and have holes with a small cap,they look nice for stock
I am sure after market has some bigger custom rims
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135418
12/16/11 07:14 PM
12/16/11 07:14 PM
Round Rock,Tx
N
Nirvana Offline
Nirvana  Offline
N
Round Rock,Tx
Jared
You can have them
That is very kind of you! Sending you a PM.
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135419
12/16/11 07:15 PM
12/16/11 07:15 PM
Abilene,Texas
ram87 Offline
ram87  Offline
Abilene,Texas
Daryl - Don't now if you remember my truck from about four years ago in Denton. It sits pretty low. You could have bought it pretty cheap, 446" motor and all. Wouldn't be much of a run around truck with the 4.88's in the rear but would get you anywhere close quick. Anyway, you can compare where the fender come to on my front and rear tires to your truck.
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: ram87] #1135420
12/16/11 07:24 PM
12/16/11 07:24 PM
yup! i remember that truck too
thats the look i wanted with mine after seeing it
whats the set up for the rear on it? i dont recall
I am running mono leafs with shackle flip/axle flop and A-body SSM lift bars.
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: scratchnfotraction] #1135421
12/16/11 07:36 PM
12/16/11 07:36 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Lol
Yeah, wasn't looking for a race truck !
daily driver type thing
No, what I was wondering is do they make rims in the 5 on 5 1/2 bolt pattern so I don't have to change it out to the 4-1/2
( I looked for a earlier model truck , prefer the egg crate grill and wanted the smaller BP )
But , everything I FOUND was pounded to snot
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135422
12/16/11 07:39 PM
12/16/11 07:39 PM
Nunnelly, TN
Kevin I Offline
Kevin I  Offline
Nunnelly, TN
I wish I could find something like that to drive so I can keep my trucks out of the weather. Is it pretty loaded up as far as options go?
Re: My new ( to me ) 1989 Dodge D-100 shortbox ! [Re: bigdad] #1135423
12/16/11 07:42 PM
12/16/11 07:42 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
iirc, the 2x4 trucks were 5 on 4.5 bolt pattern, but I could be wrong.
Kasey
