Page 2 of 3 1 2 3
Re: small block vs. big block weight? [Re: ademon] #1135172
12/16/11 08:46 PM
12/16/11 08:46 PM
Lima, Peru
domingo Offline OP
EL Master
domingo  Offline OP
EL Master
Lima, Peru
Its a sotck stroke 440 with bowl blended and port matched stealths. rpm intake. all auminum goodies, and a MP .528 solid cam. 750 cfm holley
The 340 would be stroked to 416 and the heads would be done by Ryan at Shady Dell. Victor Jr intake and probably the same ,528 MP cam but for a small block (i already have the cam). 750 cfm holley.
Re: small block vs. big block weight? [Re: fishy340] #1135173
12/16/11 09:04 PM
12/16/11 09:04 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
100lbs give or take 5 lbs! As far as handeling goes thats a huge difference..ps plus the w2 headed 340 will make more power...
Re: small block vs. big block weight? [Re: domingo] #1135174
12/16/11 09:10 PM
12/16/11 09:10 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
If ya let Ryan pick the cam ..... The small block will kick butt over the big block
Re: small block vs. big block weight? [Re: sixpackgut] #1135175
12/16/11 09:12 PM
12/16/11 09:12 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
I have always heard a bb with aluminum heads weighs the same as an all iron sb
Yup ! This one`s a 557"
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: small block vs. big block weight? [Re: ademon] #1135176
12/16/11 09:53 PM
12/16/11 09:53 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
How much would a stock block 340 with w2 iron heads and aluminum intake weigh
vs.
a stock block 440 with aluminum heads and aluminum intake?
no idea what they weigh but I know which one will make the most power.
well we know its not your 440-6 from your ET
yeah put a 340 in my car and see what it will run. I'm guessing I'm around 600 at the crank. It will take a lot of work to pull those #'s w/ a stock stroke 340. Not to mention a ton of RPM and it still won't have as much torque. and I haven't run it 100% yet...
As for weight the BB is always going to be 75-100lbs heavier than and equal S/B. I'd guess an iron headed 340 vs a BB w/ aluminum parts would be close, probably still lighter. I'd run what you have and see if you like it. The BB will make more torque and HP quicker and you won't have to run as many rpms.
Re: small block vs. big block weight? [Re: Mr.Yuck] #1135177
12/16/11 10:12 PM
12/16/11 10:12 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
Re: small block vs. big block weight? [Re: cbarracuda] #1135178
12/16/11 10:21 PM
12/16/11 10:21 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
yeah that was said before. however I'd still LOVE to see a stock stroke 340 w/ as little work as I have run anywhere close to 11's in a 3900+ car on stock leafs, 3.91 and radials.
So if any of you SB guys want to try it I'll buy ya your favorite case of brew.oh and it will be in the 11.0-teen range come spring.
Re: small block vs. big block weight? [Re: Mr.Yuck] #1135179
12/16/11 10:26 PM
12/16/11 10:26 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
http://www.youtube.com/watch?v=O-_--kAWRwk&feature=player_detailpage this is alot of rpm mr yuck...hmmmmmmmm i'd say 5800
Re: small block vs. big block weight? [Re: fishy340] #1135180
12/16/11 10:29 PM
12/16/11 10:29 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
that was with 3000 stall,it went 80's when i went to 3500 stall
Re: small block vs. big block weight? [Re: Mr.Yuck] #1135181
12/16/11 10:29 PM
12/16/11 10:29 PM
Peru
cbarracuda Offline
cbarracuda  Offline
Peru
I was just messing with you. If those 11 teens are NA in a 3900 + car, then congratulations because you have a good running 440
Re: small block vs. big block weight? [Re: fishy340] #1135182
12/16/11 10:29 PM
12/16/11 10:29 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
dude that's great for the 1/8! just kidding of course. apples and oranges, my engine in that car would run 10.40 or better.
Re: small block vs. big block weight? [Re: Mr.Yuck] #1135183
12/16/11 10:30 PM
12/16/11 10:30 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Re: small block vs. big block weight? [Re: Mr.Yuck] #1135184
12/16/11 10:31 PM
12/16/11 10:31 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
You sound just like the Chevy guys around here. I'll run your stock 318 Dart heads up in my big tire Camaro, 540, 500 shot of nitrous and $500 that says I win if you give me the leave.
Re: small block vs. big block weight? [Re: justinp61] #1135185
12/16/11 10:47 PM
12/16/11 10:47 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
How's that bro? you are comparing apples and onions. I never said I couldn't get beat by a sb. Anything can be fast. A few have made comment on how slow my junk is, and that a SB is better. So step up to the plate and build a big heavy b-body w/ a stock stroke 340 and come see me. Fact is $ for $ a BB will make more power and torque.
Oh and BTW I was being funny when I posted that mess so don't get to wound up.
Re: small block vs. big block weight? [Re: Mr.Yuck] #1135186
12/16/11 11:34 PM
12/16/11 11:34 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Bro, you haven't seen me thumpin my chest about a stock stroke 340 running 11s in a 3900# pig, so blow that on someone else. The best mine did was 11.64 in a 3240# Dart, pump 93 and a hydraulic cam.
It is actually apples to apples, just like the made up Chevy guy challenge I mentioned. Your asking someone to do something that can't be done. I shouldn't say it can't be done, it would take a ton of gear and a bunch of rpm.
Apples to onions would be your car running my Dart.
Re: small block vs. big block weight? [Re: justinp61] #1135187
12/16/11 11:41 PM
12/16/11 11:41 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
whoops try it this way,
so what's yer beef? Was it not said a SB would make more power even w/ iron heads? I made the point that the OP's BB would make more power. Then somebody decided to poke fun at me, no big deal, I poked back, then some other peole decide to take it all personal and all. If I had to choose between the 2, I'd use the BB, reguardless if it weighed a few more lbs.
Re: small block vs. big block weight? [Re: Mr.Yuck] #1135188
12/16/11 11:42 PM
12/16/11 11:42 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Re: small block vs. big block weight? [Re: domingo] #1135189
12/19/11 02:45 AM
12/19/11 02:45 AM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Well...I've actually weighed a couple of engines. My 499ci B engine with stage 6 heads and heavy Mopar intake, motor mounts, distributor, flexplate but no water pump housing (I don't use one) weighed right at 500 lbs. A dead stock '72 360 with iron manifolds (all 3), stock water pump, no distributor, flexplate or carb weighed 525 lbs. Adjust for the iron manifolds and the smallblock will be lighter but not a lot. Smallblock heads and intakes are heavy. I can also verify the smallblock bare block weight of around 160-165.
Re: small block vs. big block weight? [Re: @#$%&*!] #1135190
12/19/11 12:02 PM
12/19/11 12:02 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
Run a Indy Maxx aluminum block, light and you can build a lot of cu in with it. Cu. In.=HP + less weight=more speed.
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
Re: small block vs. big block weight? [Re: domingo] #1135191
12/19/11 01:35 PM
12/19/11 01:35 PM
AndyF Online content
AndyF  Online Content
The scale reads 490 lbs for this big block.
Page 2 of 3 1 2 3
