318 getting pulled
#1135098
12/16/11 02:58 AM
12/16/11 02:58 AM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
The 318 is going to get yanked next week. After some cleaning in the compartment the 360 will be ready to go back in.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
Re: 318 getting pulled
[Re: Abodyjohn88]
#1135100
12/16/11 09:43 AM
12/16/11 09:43 AM
dfsmopars
Kentucky
that sure is a purdy 360. specs please?
It is a good street engine. The block is a '95 5.9 Magnum. Bored .03 over, Hughes cam (.544 lift with stock rockers, ~.240 duration), RHS iron heads, KB pistons (.017 above deck), stock crank, Air Gap. Cam is degreed at 1° advanced. After installation it will get the F.A.S.T. EFI and a MSD ignition system. Should have plenty of torque and make good power. Objective is a modest 400 HP and >400 lb/ft of torque with 18 MPG and great reliability and drivability.
