compare 496 b & 499 rb #1134996
12/15/11 10:29 PM
12/15/11 10:29 PM
ky
68roadrunner Offline OP
ky
this being a race only piece. using same cam, heads, compression, everything. how would a 496 4.31x4.25 compare to a 499 4.375x4.15. i am sure the smaller bore would hurt flow some, but would have a lighter rotating weight. so what does everyone think?
Re: compare 496 b & 499 rb [Re: 68roadrunner] #1134997
12/15/11 10:46 PM
12/15/11 10:46 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Just curious what block your using for a 4.31 low deck build??
Unless these engines are all out 7500 rpm's id say there isnt much diff power wise, even then would be little measurable amount.
Re: compare 496 b & 499 rb [Re: Bob_Coomer] #1134998
12/15/11 11:01 PM
12/15/11 11:01 PM
ky
ky
383+.060 just thinking i got some parts laying around.
my 499 i turn 7000
Re: compare 496 b & 499 rb [Re: 68roadrunner] #1134999
12/16/11 12:38 AM
12/16/11 12:38 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
The rotating weight would be too negligible to matter. Bigger bore would help unshroud but would matter only a little. Id say the only difference that would matter is the 400 block is stronger and would be better that it isn't .060 over.
Re: compare 496 b & 499 rb [Re: viperblue72] #1135000
12/16/11 03:59 PM
12/16/11 03:59 PM
Maryland
340_Dart Offline
340_Dart  Offline
Maryland
Where is the 400 block in this post? i see either a 496 based off of a .060+ 383 block or a 499 based from a 440 block...
I agree though that i doubt you see any real difference in performance based on the 2 engines mentioned using the same top end components.
Re: compare 496 b & 499 rb [Re: 340_Dart] #1135001
12/16/11 04:06 PM
12/16/11 04:06 PM
Alberta Canada
StrokerAspen Offline
Alberta Canada
For a big block stock block biuld, the 400 is my #1 choice...
-Kenny
Re: compare 496 b & 499 rb [Re: 68roadrunner] #1135002
12/16/11 04:08 PM
12/16/11 04:08 PM
I like the 4.25 stroke with the BB Chevy rod sizes I have bought a 4.15 crank and had it offset ground to 4.300 stroke with the BB chevy rod journal size, 2.200 I also had the mains and counterbalnces ground down so I could put it in a 400 block, that made my 518 C.I. pump gas street motor
Re: compare 496 b & 499 rb [Re: Cab_Burge] #1135003
12/16/11 04:55 PM
12/16/11 04:55 PM
dogdays Offline
dogdays  Offline
In general the RB has better intake manifolds available.
R.
Re: compare 496 b & 499 rb [Re: 68roadrunner] #1135004
12/16/11 04:58 PM
12/16/11 04:58 PM
NC
440Jim Offline
440Jim  Offline
NC
Attached is an estimate of the bobweights, rotating and reciprocating. The actual weights will depend on the exact parts, these are just estimates for the dia and lengths needed.
The lower bobweight will help a little, but only a little perf; the main benefit is lower stress and higher durability. With a good high flowing head, 2.2+inch intake valve, etc. the bigger bore will help fill the cylinders better making more power. Think 400 block rather than 383 or 440. Or just get a megablock...
Re: compare 496 b & 499 rb [Re: StrokerAspen] #1135005
12/16/11 05:25 PM
12/16/11 05:25 PM
PA
moparacer Offline
moparacer  Offline
PA
-Kenny
X2 I buzz mine 7500
The bigger bore is a plus too.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: compare 496 b & 499 rb [Re: moparacer] #1135006
12/16/11 05:43 PM
12/16/11 05:43 PM
gregsdart Offline
gregsdart  Offline
also go to the 440Source home page, and read up on blocks. It is an eye opener, and for a race piece, only a 400 block with either the best or second best web sizes above the main bearing saddles is good enough to put to use making race hp. The best combo to date is the 512, 4.375 bore x 4.25 stroke. Cheap, light, and big.
Re: compare 496 b & 499 rb [Re: 68roadrunner] #1135007
12/16/11 07:13 PM
12/16/11 07:13 PM
Delray beach, Florida
P
Performance Only Offline
P
the force is applied to the piston. the larger the piston, the more force is exerted on the crank. for the purpose of the engine combo's listed, bobweight has at best a negligble effect on actual horsepower.
keep adding port cross section and flow ability and the difference between the two combo's grows. limit port and flow and the difference is little at best. there's a lot more that could be added to this but all it would do is create confusion for the most part.
lighter rotating assemblies have the ability to make more power, but in many cases people tend to negate those gains because they make poor choices in other areas of the build,IMO.
machine shop owner and engine builder
Re: compare 496 b & 499 rb [Re: gregsdart] #1135008
12/16/11 08:27 PM
12/16/11 08:27 PM
jonestown,pa
dmking Offline
dmking  Offline
jonestown,pa
i my self found the 440 block made late with the same thick mains ans the wide supports under the jugs as the 400s (but not the monster thick ones) it has to be better than the stock 440 block. i am not leagle to go faster than 10.s so i just hope this one does not crack. some day i will do one of these combos.
Re: compare 496 b & 499 rb [Re: 68roadrunner] #1135009
12/16/11 11:29 PM
12/16/11 11:29 PM
ky
ky
yes,yes,yes the block will break we all know that
if i had a 400 laying around i would be looking at that.(but i was not smart enough to buy any up)
maybe to make the rotating weight less, use alum rods. will alum rods fit in the 4.25 stroke 383?
it might not be a fair comparison but a comp eliminator motor makes good hp with small cubes. but does turn alot of rpm.
okay on
Re: compare 496 b & 499 rb [Re: 68roadrunner] #1135010
12/17/11 12:34 AM
12/17/11 12:34 AM
New York
polyspheric Offline
polyspheric  Offline
New York
The B has 2 minor advantages:
1. shorter cylinder wall = stronger and stiffer
2. shorter pushrods are much stiffer in the same diameter and wall thickness
Boffin Emeritus
Re: compare 496 b & 499 rb [Re: polyspheric] #1135011
12/17/11 01:29 AM
12/17/11 01:29 AM
P
P
if #1 is true, how come i consistently see the same amount of distortion in the cylinders of the low deck blocks as i see in the RB blocks when a honing plate is installed?
re; #2 buy stiffer pushrods for the taller engine if needed.
Re: compare 496 b & 499 rb [Re: Performance Only] #1135012
12/17/11 05:10 AM
12/17/11 05:10 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
#1 because the deck's are the same so the distortion you see is the same. But, the length of the cylinder is shorter so the strength of the cylinder will be stronger, thickness being equal between the two blocks.
I agree with your response to #2.
But, to continue, the 383/400 block is stronger downstairs due to the smaller main housing bore as well as it being a slightly more compact setup because of the shorter deck. The lower rod ratio will increase the bottom end and the added stroke will offset the smaller bore difference. BUT you can get a super victor intake for a 440 with a dominator flange that you can't get for a B deck block. Some builders feel it gains more to add a spacer/adapter to get a dominator to fit though so I'm not really sure of the real advantages of this.
To put it in a different perspective, I have dyno'd both combos with similar heads and cam specs. They both made right around 570 hp on pump 91. The RB had an eagle crank that hit the bottoms of the pistons with the counterweights (I really don't like eagle crankshafts). I had to grind a bunch more material out of the RB because of the larger rod journals too. I don't care if you want the RB block, go with the 2.2 journals and save some headaches. For that matter, run the 4.375 stroke and get 520ish inches.
To sum it up, if you have a 383 block, build the 496. 440, go 493 (.030 440). If you have both, decide which one is better based on a packaging standpoint: weight, clearance, etc...
Re: compare 496 b & 499 rb [Re: Performance Only] #1135013
12/17/11 11:11 AM
12/17/11 11:11 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Wow, thanks, you're the first one who thought of that.
Boffin Emeritus
Re: compare 496 b & 499 rb [Re: dodgeboy11] #1135014
12/17/11 11:28 AM
12/17/11 11:28 AM
ky
ky
that is what i was getting at. so you are saying the extra stroke 4.250 over 4.150 will help overcome the bore difference of .065 .
would a different cam and head port size help the smaller bore fill better. would you use a smaller faster port or not
Re: compare 496 b & 499 rb [Re: polyspheric] #1135015
12/17/11 03:54 PM
12/17/11 03:54 PM
P
P
right, the only problem here, other than your sarcastic attitude, is that you make it sound like the extra 3/4" is a really big deal. it's not. given the same spring pressures in either scenario, the same thickness pushrod would work in either.
your great with the math, but i get the feeling you have very little practical hands on experience with this stuff.
as far as the cylinder walls being stronger because they're shorter, that's more myth than fact. we aren't talking about a machined tube here, it's a cast iron cylinder wall with imperfections all over the outside cast wall.thick and thin area's exist in both B and RB blocks. if you have a thin wall in the middle of the B block cylinder, it's a weak area just like it is in a RB cylinder. the only true advantage to the B block is the stronger bottom end.
in the 35 years i've been building these engines i've yet to see more than a handful that actually had thick symmetrical bores on all 8 cylinders. if you could actually find one, then i'd say THAT particular block would be stronger. we don't work in the theoretical world though.
in response to the block distortion from a cylinder head or honing plate, there's no difference in the strength there either. the deck is connected to the cylinder walls. if you torque the fasteners on either block they both distort the same amount. if the cylinders were stronger in one vs. the other, that wouldn't happen. the distortion shows up in the bore as well as the deck.
