L 2426 360 piston #1134906
12/15/11 08:36 PM
12/15/11 08:36 PM
Mississippi
bcr Offline OP
bcr  Offline OP
Mississippi
Digging through parts boxes accumulated over the years and found 7 L2426 .030 pistons along with 8 rods with bronze bushed small end and a MS-3049 casting #. I cant find any info on the pistons through TRW or Speed Pro lit.
Question; anyone happen to have one or two of these pistons in .030 laying around? Any info on the rods?
Re: L 2426 360 piston [Re: bcr] #1134907
12/15/11 08:54 PM
12/15/11 08:54 PM
dogdays Offline
dogdays  Offline
They are early 340 rods. There is a forging number somewhere on the rod that ends in 496. I believe the later ones shared with 360s were 645. All MOPAR rods are forged. Only castings have a casting number.
Probably another Speed Pro piston from the days when they weren't combined with TRW.
R.
Re: L 2426 360 piston [Re: dogdays] #1134908
12/15/11 11:28 PM
12/15/11 11:28 PM
What Dog said & might google it & in one of the googled' threads find what it is so you can locate a single
Re: L 2426 360 piston [Re: RapidRobert] #1134909
12/16/11 12:36 AM
12/16/11 12:36 AM
Mississippi
bcr Offline OP
bcr  Offline OP
Mississippi
Well I found by Google an older post here that states the L2426 piston is for a 360 and has 1.704 comp height,.407 dome,.984 pin. I think this will do what we need if we can only find one or two or three----to complete the set.
