Re: small block rocker arms
[Re: moparmade43]
#113472
09/01/08 12:25 PM
09/01/08 12:25 PM
Posts: 15,487 Florida
scratchnfotraction
they are off set a little and go on the shaft as left and right offset per cyl so on the shaft it will have a left/right rocker per cly, off set the correct way to line up on the valve tip should be in an engine manual ![](/ubbthreads/images/graemlins/beer.gif)
[Re: moparmade43]
#113476
09/01/08 12:47 PM
09/01/08 12:47 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Look at the picture. Where the pushrod cup is located in the rocker, to be specfic. The "L" rockers have the cup biased to the left and the "R" rockers have the cup biased to the right.
As for slop, all the factory ones I have messed with had some slop. But the angle of the pushrod will take up the slop in operation. The pushrods tend to push the rockers apart.
